![]() Drives: 2017 ZL1 Join Date: Nov 2009
Power Stop Z-26 pads
I just read a thread that GT-ER posted on how bad his rotors look using the Z-26 brake pads. I put mine on at 900 miles and only have about 2,000 miles on them.
After seeing his rotors, I am seriously considering going back to the the stock pads. So far no issues on mine with mild driving. When I installed my Z-26 pads there was a lot of people on here installing those pads. Is anyone else that installed those pads having the same issues with build up on the rotors? |
![]() Drives: 2017 ZL1 A10 Summit White Join Date: Apr 2018
I would stick with the oem pads. They are great.
902HP 858TQ
Drives: 2018 ZL1 A10 Join Date: May 2018
I have no problems with mine... I still love them
Thank you Al Oppenheiser!
5000 miles and 20-ish months without issues. Rotors look just fine.
2018 ZL1 1LE
Drives: 2018 ZL1 1LE Join Date: Aug 2017
I installed mine early Spring, 1,500 mi and no issues. Makes my detailing process so much easier too. Why would you go back to OEM if you are not having problems? Just make sure you use a mild abrasive, like steel wool, to clean off the pad deposit on the rotors before installing any others.
![]() Drives: 2018 Camaro ZL1 Join Date: Feb 2018
If yours are fine I agree you should just leave it alone. Maybe mine was a bad batch, or maybe I drive to aggressively, I don't know. Mine were great at first, but now they suck. :-(
#7 |
![]() Drives: Garnet Red / ZL1 1LE Join Date: Apr 2016
As someone who used these pads on my Z06....If the only use is for the street then go with these pads. If you use it on track or for any spirited drives you’re better off with the stock pads as they have a better bite. In a heavy car like ours, I would rather go for bite.
These pads work as advertised_ virtually no brake dust.
#SAVETHEMANUALS
#8 |
![]() ![]() Drives: Red hot ZL1 A10 2017 Join Date: Nov 2016
Z26
From 1000 miles to 17000 miles No issues Tracked the car with z26 once No issues neither with pads nor rotors |
#9 |
![]() Drives: 2017 ZL1,2013 ZR1, 1952 C3100 Resto Join Date: Jun 2017
13,000 miles on mine with no problems...…….
2017 ZL1,Mosaic Black, auto,nav/pdr, Roto Fab,Mamo
2013 ZR1 60th Anniv. 1952 C3100 resto-rod. LS6, 4L60e, 228R cam |
#10 |
![]() Drives: 2019 ZL1 Crush Join Date: Jan 2019
no issues from me as well
#11 |
![]() ![]() Drives: 69 GTO, 05 GTO, 2018 Silver ZL1 Join Date: Jan 2012
19,000 miles...rotors look fine. I did the recommended break-in!
Several trips to Mexico, many 0-100-0, and a tail of the Dragon cruise! They can't handle CONTINUAL hard pounding, but no dust and thoroughly cleaning wheels every 3 months is worth it! |
