Old 08-28-2019, 04:23 PM   #1
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
Methanol injection!!!
Calling all meth heads!
Next stage of my build is meth injection . IMO good way to cool down and boost HP especially since no e85 in my area. I am looking for some insight for my forum peeps.
What methanol injection kit are people running on their lt4 zl1? I am considering the snow performance stage 2 kits
Thoughts and comments?
Zigg L1 is offline   Reply With Quote
Old 08-28-2019, 07:39 PM   #2
RDBill
902HP 858TQ
RDBill's Avatar
Drives: 2018 ZL1 A10
https://race-proven-motorsports.mysh...e52c6b03&_ss=r
I've had no problems with it at all. I like that it has a trunk mounted tank so I don't lose my washer solvent bottle
RDBill is offline   Reply With Quote
Old 08-30-2019, 09:09 PM   #3
Zigg L1
Zigg L1's Avatar
Nobody has any interest in the methanol injection system to cool down the system and add huge power???
Old 08-30-2019, 09:37 PM   #4
hammdo
'It's an experiment'
hammdo's Avatar
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE
ProMeth — I have their LSA post rotor system — I’d contact Rodney and see if he has a post rotor setup for the LT4
Mine:
I do run E85 pump gas too...
-Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari
See My Build: http://www.camaro5.com/forums/showthread.php?t=385577
hammdo is offline   Reply With Quote
Old 08-30-2019, 10:05 PM   #5
Markoz28
Drives: 18 ZL1 nightfall grey A10
I have always wanted to add meth. There are not many that share their experiences. I’m also looking into the snow stage 2.
Markoz28 is offline   Reply With Quote
Old 08-31-2019, 05:35 AM   #6
Zigg L1
Zigg L1's Avatar
I have the NX Lid now. Snow recommend the 8 nozzle system to hook up to the lid. Which would nice with the nard line Stainless lines running to each port. Total was about $1100.
I am not sure if the throttle body spacer with the injection port would fit with the LT4 and the roto-fab. There is only about 3/8" between the intake and radiator. The single nozzle kit is about half the price!
Not certain on which injection point would be best. My good friend had his tapped into his intake on his 5th gen and it works well there.
Snow tried to sell my on the stage 3 but I don't think the juice is worth the squeeze on that. Stage 2 would work just fine with the variable rate control from the boost.
Old 08-31-2019, 02:34 PM   #7
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Alkey is a popular system
Kooks full exhaust, Roto Fab, Whipple,Williams 103, Fore innovation, JRE cam and tuning
F419sr1 is offline   Reply With Quote
Old 09-02-2019, 01:13 PM   #8
gdawgg
Drives: 2018 ZL1
I run an Alky Control dual nozzle system. Take a look at this post to see my isolated gains from meth after adding to previous mods.
https://www.camaro6.com/forums/showthread.php?t=545587
gdawgg is offline   Reply With Quote
Old 09-02-2019, 01:44 PM   #9
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Nice numbers. I have closet to the same build as far as supporting mods go. I have to do heads and cam over the winter. My whipple has a 3.5 upper and stock lower. Hope to see good numbers
Old 09-03-2019, 09:41 AM   #10
speedraider
speedraider's Avatar
Drives: 2016 Z06, 2017 ZL1
Alky Control
speedraider is offline   Reply With Quote
Old 09-03-2019, 10:01 AM   #11
Jason18ZL1LE
Drives: 2018 ZL1 1LE
I live near E85 and also don’t want to worry about a tank running dry or a pump failing mid pull. Meth is cool, but not for this guy
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
Old 04-30-2020, 08:41 PM   #12
Zigg L1
Zigg L1's Avatar
bumping up my own thread. I am still contemplating using meth injection or not. I did find a thread from Ted @ Janett Racing and he was against it. What is people honest opinion. Is meth worth it? Is it safe?
I know it cools IAT Temps and boost octane to me sounds good a win win. Yes a pump could fail but if you rebuild them and maintain it as per manufacturer recommended you should be fine.
Is there any downsides on engine internals with running it?
Old 04-30-2020, 10:07 PM   #13
F419sr1
F419sr1's Avatar
Drives: 2017 ZL1
Problem is if the pump fails while your spraying or doesn’t spray you can loose your motor.
Old 04-30-2020, 10:33 PM   #14
Markoz28
I’m running meth and will be purchasing a send pump soon. Not bc anything is wrong with my current but I want to send it to get rebuilt ever year and use one in its place. This way I don’t have down time and the pumps keep fresh. Pumps are cheap too. About $150 tops.
