Old 08-27-2019, 10:39 PM   #1
NA18CamaroSS
NA18CamaroSS's Avatar
Drives: 2018 Chevrolet Camaro 2SS 1LE 6M
PCM pulling timing at 6k rpm
Having an interesting issue with my 2018 Camaro SS 1LE. Had the car tuned a couple of weeks ago and I have been sorting out a few issues. The part throttle was a little wonky and playing with the throttle tables smoothed out that problem. I am seeing a strange problem at full throttle. The PCM is pulling 10-15 degrees at around 6,000 RPM at full throttle. It's not knock retard. No matter if I am running 21 degrees or 25 degrees, the same thing occurs. The only mods on the car are a Soler Performance throttle body, a Green filter drop in air filter, and a flex fuel kit. The E85 that I am getting at the local pumps runs about 78-80% ethanol. I have attached a screen shot of the datalog right before the problem occurs, and one of the actual issue occurring. Ideas?
Bolt-ons.
NA18CamaroSS is offline   Reply With Quote
Old 08-29-2019, 02:00 AM   #2
6spdhyperblue
Drives: 2SS 1LE
Are you logging all the torque pids?
Old 08-29-2019, 10:05 AM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
That's a torque table issue. It'll pull timing if your max torque is over peak torque or if you eng torque is over max torque. It's not very fun to work with but I'd take it back to your tuner. They most likely didn't dial in your VE tables
Juiced1 is offline   Reply With Quote
Old 08-29-2019, 01:26 PM   #4
NA18CamaroSS
Thanks for the input. The torque limits were moved up by 25%. Not sure which torque PIDs would be helpful in diagnosing this issue. Could you be more specific?
Bolt-ons.
Old 09-09-2019, 01:43 AM   #5
NA18CamaroSS
I finally figured it out. For some reason the PCM is seeing more than the estimated max value for the MAP sensor. Upping the value eliminated the problem.
Bolt-ons.
Old 09-11-2019, 04:24 PM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
you shouldn't be over 100 unless you are running boost.
Old 09-12-2019, 01:05 AM   #7
NA18CamaroSS
The stock value for estimated MAP maximum is 105 kPa. Datalogs show that the maximum logged MAP value is 100 kPa. Not sure why the PCM is reacting to the MAP value the way it is, but moving the estimated MAP maximum up to 135 kPa eliminated the issue. I have attached a screen shot of a datalog I just pulled tonight, with a nice straight timing curve-no timing being pulled at 6k RPM.
Bolt-ons.
Old 09-28-2019, 09:15 PM   #8
floridanick
Drives: Chevrolet Camaro 2SS
this is pretty interesting. I would like to hear more about what the values should be and how/why you are maxing out if you are n/a?
floridanick is offline   Reply With Quote
Old 09-30-2019, 09:47 AM   #9
TJay74
To really be able to see what is pulling any timing you need to log all of the timing systems so you can see what is pulling the timing.
Torque management timing
Timing advance
PE timing
KR timing
Flex timing
Coolant timing
IAT timing
I think there is something like 5-8 timing PIDs that need to be logged so you can see what is pulling the timing. Glad you found, hope that helps out for the future logs.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 10-30-2019, 03:20 PM   #10
Z0Tex
@texan.1le
Z0Tex's Avatar
Drives: '18 Camaro 1SS 1LE, PDR
I believe I'm having the same problem as you: timing dip at 5800 rpm and then back up to normal at 5900ish at WOT. Do you, or does anyone, know where this MAP Maximum value would be found in HPTuners?
'18 1SS 1LE - "Mongoose"
'15 Malibu 2LT - daily
Z0Tex is offline   Reply With Quote
Old 11-08-2019, 08:14 AM   #11
Z0Tex
@texan.1le
Z0Tex's Avatar
Bump.
Old 11-08-2019, 08:19 AM   #12
floridanick
Zero out your Static knock table.
Old 11-08-2019, 08:45 AM   #13
wookwook
wookwook's Avatar
Drives: 18 Camaro LS M6
If your graphing, check the HZ peak, and look up in the limit table, 13300hz maybe? It may be MAF HighVoltage Fail. Its a suggested remedy for boosted tuning limits. I don't have the path in front of me but should be easy to located under Air menu. HPT.
wookwook is offline   Reply With Quote
Old 11-12-2019, 09:15 AM   #14
Slowhawk
Drives: 1999 Trans Am
I see your not logging actual torque 1+2. Those will show torque drop in that area.
Going to the torque model tables and adjusting airflow would get rid of it too.
Slowhawk is offline   Reply With Quote
