Old 08-27-2019, 10:36 AM   #1
Meger7
Drives: Chevy Camaro
Bogging down and super slow acceleration
I have a 2017 Camaro V6 LT2. It bogs down when accelerating especially when going around curves. It drives like a grandpa car. My 2010 camaro had amazing pep and it was a V6 as well. Any suggestions that may help would be appreciative! This has been going on for a few months now. Dealership says nothing is wrong, of course!
Meger7 is offline   Reply With Quote
Old 08-27-2019, 10:44 AM   #2
Mighty Mouce
Drives: Camaro
Bad fuel pump.
Mighty Mouce is offline   Reply With Quote
Old 08-27-2019, 01:55 PM   #3
PnCRedJwl2SS
Howdy! Pete here...
PnCRedJwl2SS's Avatar
Drives: 2017 50th Anniv 2SS, A8, NPP, MRC
Originally Posted by Mighty Mouce View Post
Bad fuel pump.
Jinx!
PnCRedJwl2SS
2017 50th Anniversary Edition, A8, NPP, MRC, w/Sunroof and Glow-tie!
___________________________________________
Ordered from GM
Delivered to dealership and home 9-16-16
This car is a beast!
PnCRedJwl2SS is offline   Reply With Quote
Old 08-27-2019, 02:00 PM   #4
IneedAZ
IneedAZ's Avatar
Did you check the obvious? Dirty Air filter, dirty TB, plugs look ok?
Also, you may want to fix the spelling of Camaro in your Avatar.
Old 08-27-2019, 02:03 PM   #5
Mov Ov3r
What speed limit?
Mov Ov3r's Avatar
Drives: 2017 SS 1LE
Mov Ov3r is offline   Reply With Quote
Old 08-27-2019, 02:10 PM   #6
IneedAZ
IneedAZ's Avatar
also, does it happen no matter where you buy the gas, or are you always buying gas from the same station?
Old 08-27-2019, 05:35 PM   #7
Meger7
Sure did. And thank you!
Old 08-27-2019, 05:37 PM   #8
Meger7
I usually do buy gas at the same station. I'll try a different one and see if that helps.
Old 08-27-2019, 05:46 PM   #9
IneedAZ
IneedAZ's Avatar
Might take a tank or two to see if u notice a difference.
Old 08-27-2019, 09:50 PM   #10
MosaicX1LE
Drives: 2017 MBM Camaro V6 1LE
The stability control kind of feels like that. Turn everything off (hold 7ish seconds) and then see, safely of course.
MosaicX1LE is offline   Reply With Quote
Old 08-28-2019, 02:13 AM   #11
s346k
s346k's Avatar
Drives: like an old lady
traction control
Old 08-28-2019, 12:37 PM   #12
mrgoodbytes
mrgoodbytes's Avatar
Drives: '18 2SS/EU (+Recaros) M6 Red Hot
I’d say traction control as well. It works in conjunction with steering wheel angle. My SS does the same thing. Tried disabling traction control on an empty parking lot in an industrial area after hours to test it. And even going as slowly as possible and giving it some throttle it went completely bananas. Definitely a good thing the traction control gives some restraint, as I nearly drove the car into a light post. I was shocked at how much torque it really has. The traction control also does a great job hiding that.
mrgoodbytes is offline   Reply With Quote
Old 08-28-2019, 03:02 PM   #13
Meger7
Now that would make sense! My dog always hits the traction control button and turns it on! Thanks guys!
Old 08-28-2019, 03:28 PM   #14
MackSteelPrivateEye
WIth my TC on its still nowhere near bogged down, just as torque. TC doesn't kick in until it notices a loss of traction not before.
