08-27-2019, 09:28 AM | #1 |
Scott S
Drives: 2011 Camaro 2SS Join Date: Sep 2018
ISO: M6 driveshaft
Looking for a driveshaft from a 2012-2015 ZL1 with Manual tranny.
769HP/699 Torque LS3 heads ported and polished with BTR Spring kit & Trunion upgrade, LSA supercharger ported by DC Porting, 102MM throttle Body, 2.40 pulley upper pulley, Innovators West 10% Overdrive lower, BTR Stage 3 PDS Blower Cam, Mighty Mouse Catch Can, SMG Flex Fuel kit, SMG Aux Fuel System, FIC 1000 Injectors, MGW Flat Stick Shifter, RPM Stage Vll Transmission, McLeod RXT clutch, ARH 1 7/8 Headers, 3" X-pipe with Borla S-Type mufflers, ZL1 3:23 rear diff and Axles, 1LE suspension. Bmr Bushings in back. TUNING AND SPECIAL ALIGNMENT BY CARL@Twincitiesperformance
08-27-2019, 01:33 PM | #2 |
Scott S
Found one...
10-05-2019, 10:32 PM | #3 |
Drives: 2010 2SS Camaro, ‘18 Sierra Denali Join Date: Jun 2019
Was this a direct fit to your 6speed trans with the zl1rear end?
02-20-2020, 11:49 AM | #4 |
Scott S
Not until I changed the hub on the back of the transmission.
02-20-2020, 11:59 AM | #5 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
I have one if anybody is looking.
