Old 08-21-2019, 02:24 PM   #1
rmh3
Semper Fi!
rmh3's Avatar
Drives: 2018 ZL1
How do you clean the debris off the Aux trans cooler?
Hope this is not a silly question, but does anyone have a simple way of removing the debris that is caught on the cooler that sits flat on the front end of grill?
Got some leaves and other stuff stuck in there and cant reach my hand in there to remove it. TIA
rmh3 is offline   Reply With Quote
Old 08-21-2019, 02:31 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Shop vac with extension
Old 08-21-2019, 02:45 PM   #3
ChrisRa13
Drives: 2019 Camaro ZL1 1LE
^This
ChrisRa13 is offline   Reply With Quote
Old 08-21-2019, 03:46 PM   #4
rmh3
Semper Fi!
rmh3's Avatar
Drives: 2018 ZL1
Thanks! I have a hand held vac...maybe time to get a shop vac.
Old 08-21-2019, 05:04 PM   #5
Mark R
Drives: 2018 ZL-1
I'll do that too. That whole area has about 25 grasshoppers and other nasty dried bug carcasses in there.
Old 08-21-2019, 05:17 PM   #6
Glen e
Glen e's Avatar
Drives: 2LT RS/HR-V
There is another alternative. Poorboys bug squash, melts bugs but is not harmful to any of the metal or paint. Sprayed on liberally, really getting down into the vanes , wait a half hour, and then take a moderate water hose stream to it , being careful… Once it’s real clean, pull the rest of the stuff out with the shop vac thin nozzle.....go slow.
This usually occurs because you’ve taking a long trip. Around town it doesn’t seem to get clogged up. This is the reason the Novistretch bra is so good for long trips, as it protects all these radiators…
Old 08-21-2019, 06:36 PM   #7
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
+1 to the shop vac with the skinny upholstery attachment.
Whatever you do... do not spray a pressure washer into the grille area or you may flatten all the fins on the radiators.
