Old 08-21-2019, 04:05 AM   #1
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
what is needed to run a ZL1 low side intank pump?
tune change? running E90 and planing on cam and heads in the future.
Old 08-21-2019, 09:03 AM   #2
L78toLT1
L78toLT1's Avatar
I don't think anything is needed. I swapped mine out in preparation for going FI. At the time I was tuned, running E85. Also had CAI and headers . Car didn't seem to notice the change i.e. no CELs
Baby Blue
Old 08-22-2019, 01:45 AM   #3
JCunningham
Drives: 2017 2SS M6
why is it everywhere i look for a ZL1 pump they list the same pump for the 17 SS and ZL1.
Old 08-22-2019, 07:52 AM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I did AC Delco M100183 for the LT4 in-tank pump. Hopefully I did the right one...lol
You’ll also want to change the desired fuel pressure in the FSCM. Will cost you one credit with HP Tuners.
Old 08-22-2019, 09:40 AM   #5
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
1LE SS and ZL1 have the same pump. There are definitely 2 different part numbers available. Look up Wildhammer or SkidMark garage. That being said I doubt you will need to touch the stock fuel system NA unless going Max effort 600whp+.
Old 08-22-2019, 01:16 PM   #6
JCunningham
Drives: 2017 2SS M6
im almost maxed out with what i have now on E90. plans are cam and heads. ill get the 38% fuel lobe so that will probably keep it safe on E but i was thinking since i have the drive shaft out might as well pull the tank. the M100183 pump is only $124 https://www.rockauto.com/en/parts/ac...assembly,10147
Old 08-22-2019, 02:47 PM   #7
6spdhyperblue
Drives: 2SS 1LE
King how lean do you go for a stock lt1 fuel system support anything but fbo. I’m fbo as far as the fuel systems concerned on e70 and 5.5ms on the injectors even at a .89 lambda
Old 08-22-2019, 03:12 PM   #8
KingLT1
KingLT1's Avatar
im almost maxed out with what i have now on E90. plans are cam and heads. ill get the fuel 38% lobe so that will probably keep it save on E but i was thinking since i have the drive shaft out might as well pull the tank. the M100183 pump is only $124 https://www.rockauto.com/en/parts/ac...assembly,10147
Yes makes sense.
38% cam will give you another 100+ whp of fuel headroom on the highside.
E90 is probably eating up some fuel headroom.
.88-.90
5.5 isn't bad.
Bigger fuel lobe will net will raise the ceiling quite a bit on the high side. Pray has several heads/can cars running E on stock fuel system.
AFR isn't the only thing to consider either. EOIT plays a big part in extending the fuel injectors capacity.
Old 08-23-2019, 12:54 PM   #9
JCunningham
Drives: 2017 2SS M6
E90 is what we have at the pump and i dont want to bother mixing. So basically unless I go FI i dont need the pump?. im 4ms on 93. I havent run a log on E90 but i believe my tuner said I was at 4.5ms and he doesnt like going over 5.
Old 08-23-2019, 01:09 PM   #10
6spdhyperblue
Drives: 2SS 1LE
I would think he said 5.5ms and doesn’t go over 6. A good amount of people say around 6 is the limit too. That would make more sense Seeing where I’m at and you’re running e90. Unless you’re at a crazy altitude.
Any benefit to upgrade the low side on a fbo car?
Old 08-23-2019, 05:59 PM   #11
oldman
Drives: SS 6 speed of course
You need to check the lowside fuel pressure 60 to70 is what my tuner likes. Anyway other than the convertible needing a bunch of other stuff. You just need really small hands to plug the stuff in... probably time to be nice to the wife.
Old 08-23-2019, 07:40 PM   #12
JCunningham
Drives: 2017 2SS M6
No wife and hands are catchers gloves.
Old 08-23-2019, 09:27 PM   #13
oldman
Um, find the smallest guy friend. I'm not kidding it was really really tight.
Old 08-23-2019, 09:41 PM   #14
JCunningham
Drives: 2017 2SS M6
is it illegal if i pay a hooker to do it.
