Old 08-20-2019, 03:03 PM   #1
The Specialist
The Specialist's Avatar
Drives: 2018 Summit White Camaro SS 1LE
Change my Oil?
Ok, come this October I will be putting away my 1LE for 6 months.
Sleeping in the garage.
I'm guessing the oil in her will have right around 3k Miles.
Should I change the oil before I put her away or after I wake her up after 6.5 months?
The Specialist is offline   Reply With Quote
Old 08-20-2019, 03:14 PM   #2
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
if the oil had less than 1000 or so, Id leave it, but 3000 I would change before it goes to sleep. only what I would do....
Old 08-20-2019, 08:31 PM   #3
cnc237
Drives: 2019 Camaro 2SS 1LE
Great question, I will be doing the same.
My thoughts were if I am at that 1500 mi mark i would do the oil trans and rear diff before putting her up for the winter.
Curious to see everyone's responses.
2019 2SS 1LE
cnc237 is offline   Reply With Quote
Old 08-20-2019, 08:36 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
Change it before.
Why put your baby to bed with a dirty diaper?
Old 08-21-2019, 05:08 AM   #5
The Specialist
trans and rear diff...….
Why?
Old 08-21-2019, 05:22 AM   #6
The Specialist
Change it before.
I'm thinking the new oil will get somewhat contaminated during the first start due to what ever doesn't come out of the pan, along with all the parts coated with old oil.
After putting in new oil, the oil is going to sit in the garage at the bottom of the pan for 6+ months with the temperature ranging from -15F to 50 above degrees.
In the spring when I wake her up, will that fresh oil really be still fresh and new?
Maybe I should go balls to the wall, change it when I put her away and change it again when I wake her up.
Old 08-21-2019, 06:18 PM   #7
RLem619
RLem619's Avatar
Drives: 2019 Camaro 2SS A10
If it were me, I wouldn't change and then sit it for over 6 months. That sounds ass backwards. You only have 3000 miles on the oil, i'd leave it in over winter, then when you pull it out of hibernation, change the oil and be fresh for the driving season.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
RLem619 is offline   Reply With Quote
Old 08-21-2019, 06:27 PM   #8
Gunkk
Gunkk's Avatar
So you willingly put the baby to bed with a dirty daiper, letting all the nasty acids, water and other contaminants eat away at its tender internals and underside.
Your baby sez:
Old 08-21-2019, 06:46 PM   #9
RLem619
RLem619's Avatar
Your baby sez:
Pretty sure that his oil with 3k on it, would test perfectly fine to sit 6 months without damaging anything.
Old 08-21-2019, 07:15 PM   #10
Wierd Harold
Drives: 2017 2lt rs
Agreed,leave old oil in.watched my oil life monitor go to "0"within a 5 Mile drive in the spring.
Wierd Harold is offline   Reply With Quote
Old 08-21-2019, 10:57 PM   #11
breakskeet
Kevin
breakskeet's Avatar
Drives: 2018 Callaway Camaro ZL1 1LE
Change it but do not reset the OLM until she comes out of hibernation. Leave yourself a note on the steering wheel so you remember to reset it. That way she sleeps clean and in the spring starts out at 100%
breakskeet is offline   Reply With Quote
Old 08-21-2019, 11:38 PM   #12
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
Absolutely change it! Contaminated oil can be corrosive to internal engine parts. It’s very cheap insurance for me.
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
Old 08-21-2019, 11:57 PM   #13
Whocares05050
Drives: 2018 Camaro SS 1LE
You should ALWAYS change your oil when storing it.
Whocares05050 is offline   Reply With Quote
Old 08-22-2019, 08:52 AM   #14
The Specialist
I think I'll nip it right in the bud and do it twice.
I'll change it before I store it. Then, take if for a 20 minute ride in the spring and change it again.
$50.00 each way, what the hell. It's easy and takes thirty minutes at best with the race ramps.
I'll even change the filter each time...
