![]() Drives: 2019 Camaro ZL1 1LE Join Date: Jun 2019
Trunk Won't Open
Had a great weekend with my boys and wife in the ZLE. Unfortunately, we went to a little local spot where there are quite a few cars. Wife had to get something out of the trunk and went to shut it. I *think* she started to use the safety release from the inside of the trunk to pull it shut and I stopped her and said just lower it a little and once it gets half way the spoiler weight will shut it for you. Can't get mad at her because she didn't want to touch the lid to lower it and risk scratching the car with her Nails, Rings, Bracelets etc. Anyways, now the fob and the button on the door actuate the release but it doesn't "pop" if that makes sense? Any way to manually do this or will this be a warranty issue for the dealer? Car has 700 miles on it and had no issues with the trunk previously.
![]() ![]() ![]() Drives: 2017 Camaro 1SS, 2023 Colorado Z71 Join Date: Sep 2017
When you say it doesnt "pop" open, does that mean it doesnt open at all? or you just have to lift it?
Go in (or send one of the boys in haha) through the back seat and open it from the inside to make sure its not jammed in the shut position.
2017 1SS, Summit White, Black 2SS Interior, MRC, NPP
2023 Colorado Z71, Nitro Yellow |
It doesn't open at all. I can hear the actuator working like it should but the trunk never actually releases. I thought the Zl1 1LE seats didn't lay down?
#4 | |
The trunk latch may need some adjustment. Can you pull the trunk lid up when you hear the click after pressing the release button? Given the mileage and depending on your willingness to mess with it, I'd probably just take it in. BTW I usually close the trunk by gently grabbing and pulling on the black plastic sheath around the latch assy on the lid.
Oh, and your wife's a definite keeper
![]() Drives: 2016 Camaro 2SS Convertible A8 Join Date: Apr 2019
#7 |
#8 | |
I have tried lifting up on it at the same time. Also tried applying even and constant pressure while lifting it up. Did the same with constant pressure pushing down on the lid while hitting the unlock button. |
#9 |
![]() Drives: gas powered Join Date: Jan 2019
Just to warn you mine did it once and when I did get it open it took me a while to get it to close and latch.
Id let the dealer mess with it while its closed and you can drive it. |
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
Can you release the seats, crawl into the trunk and use the release latch, maybe it's like stuck half way or something.
#11 |
![]() Drives: 2017 A10 ZL1 KG Join Date: Oct 2014
I have to slam mine a little hard.
#12 |
Dumb question but did you try the button on the door panel.
Sometimes when my Fob doesn't work or the button by the license plate the door will work. |
#13 |
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
This happened to my trunk once too. I had to push down on the lid really hard a few times to get it to completely lock. After that, it would open again.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#14 |
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound) Join Date: Feb 2019
Yep this has happened twice on my ZLE and I put my palm on the wing and pushed down (pretty) firmly and then it was able to pop when I tried it again.
