08-15-2019, 06:34 PM | #1 |
Drives: '18 Camaro 2SS 1LE M6T Join Date: Aug 2018
AC Recharge questions
Can anyone tell me where I recharge the AC from? I can only find the high pressure input for the AC. I recently replaced my condenser myself because a rock cracked it and the dealership wanted like 1,500 to replace it and refill it. I'm now trying to find out where the input is to recharge the AC with Freon but I can't find it. Couldn't find anything online either. Pictures are best but a typed out explanation on where it is will suffice. Thanks guys!
08-15-2019, 06:45 PM | #2 | |
Drives: 2016 2SS 8AT Join Date: May 2018
08-15-2019, 06:54 PM | #3 |
It has R134A.
08-15-2019, 09:28 PM | #4 |
Drives: Camaro SS 1LE Join Date: Aug 2018
08-16-2019, 12:43 AM | #5 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
You need to vacuum out the system before you charge it. Also, you need to change the accumulator/drier and measure the oil in the old one so you can add fresh oil to the new one.
08-17-2019, 02:22 PM | #6 | |
08-17-2019, 02:23 PM | #7 |
08-17-2019, 05:41 PM | #8 |
Drives: 2017 ZL1(Silver) - A10, Stock Join Date: Jan 2019
I think you’re incorrect in type of refrigerant and have r-1234yf since your car is a 2018. I just had dealer replace a cracked AC line and mine was r-1234yf. I learned they started using in Camaros in 2017 and sucks because it makes it so home mechanics can’t do recharge......or at least makes it much more difficult. Most likely reason the recharge port dosent match as they different ports depending on refrigerant.
Good luck and hope I’m wrong, because the yf refrigerant is much more expensive as well.
2017 ZL1(Silver) A10
08-17-2019, 05:47 PM | #9 | |
Drives: 17 SS a8 Join Date: Feb 2010
I am not advocating for this but there are people out there changing to 134a, they make adapter fittings and the pressures/temps are very close to the same.
best et 5.83@121 with the 5.3 http://www.camaro6.com/forums/showthread.php?t=465472 |
08-18-2019, 04:17 PM | #10 | |
Thats news to me that they are swapping over to 134, ill have to look into that. Last a/c class I took spoke of "dangers" when doing that. Doesnt mean it cant be done. |
01-30-2024, 11:47 AM | #11 |
ZL1 Believer
Drives: 2019 Camaro ZL1 Join Date: Oct 2020
I would love to have a step by step with the results. Because here in Thailand, 134a is still what is being sold in brand new 2024 vehicles, all of them. I need to recharge my system after my Interchiller install, and this would be the perfect time to do it. Changing over is definitely not illegal here. In fact, I can’t even buy YF without importing it….. I think it’s because 134a’s performance is about 15% better from what I read. And here in Thailand, it’s really hot. That’s probably the reason Thailand has not switched over from 134a and it doesn’t look like they will anytime soon.
01-30-2024, 12:31 PM | #12 |
Drives: 2018 Hyper Blue Metallic SS 1le Join Date: Oct 2023
I went through this with my 2018 Grand Cherokee, I went out and bought a can of recharge, the 134a and 1234yf fittings are actually close in size, it was driving me nuts until I googled it lol
01-30-2024, 09:25 PM | #13 |
Drives: Chevrolet Camaro Join Date: Feb 2020
Not saying it's the right thing to do, but I would convert it over to R134a. The oils are compatible, and you can get adapter fittings / vacuum pump / and manifold gauges to do the work yourself for less than it costs to have someone refill with the YF stuff. Not to mention the 134a runs about 3-4 degrees cooler, plus is way cheaper to refill down the road. This has been my experience anyway.
01-31-2024, 10:52 AM | #14 | ||
Video shows the recharge, but not the best visual of the ports he is using for high and low side. This video shows the two ports. The high side one is weird, as it actually looks like it tee's off the low side line. Looks like a weird fitting that bulges around the low pressure line. Maybe someone can explain the logic in that: Best picture I could find. You can see the skinny liquid line coming off the bulge area: https://www.camaro6.com/forums/showp...29&postcount=1 |
Tags |
a.c., condenser, freon, refrigerant |
