Old 08-15-2019, 02:35 AM   #1
my maro
Drives: 2018 camaro 1SS
Send a message via ICQ to my maro Send a message via AIM to my maro Send a message via MSN to my maro Send a message via Yahoo to my maro
Amsoil solved my motor tapping issue
2018 camaro 1ss had a top end tapping noise (sounds like a lifter starting to collapse). Took to dealership where i bought the car , they could not find anything wrong, compared to like car,(same motor). GM sent a V8 specialist to the dealership and he check stuff,(wont tell me what) and he said "normal". Not happy with this i start my research, and the little this GM employee did tell me in his RO report was engine oil could make a difference.
I put Amsoil 5-30 full syn singnature siries oil in the thing and tapping is GONE!
Just wanted to shair, steve hill
my maro is offline   Reply With Quote
Old 08-16-2019, 11:01 AM   #2
MackSteelPrivateEye
They don't call it "Mystery Oil" for nuttin'.
Ooops ...I was thinking of Marvel Mystery Oil.
Old 08-16-2019, 01:55 PM   #3
ssmofo
ssmofo's Avatar
Drives: Chevy Camaro
Thanks for shairing
ssmofo is offline   Reply With Quote
Old 08-16-2019, 02:05 PM   #4
6spdhyperblue
Drives: 2SS 1LE
Thicker oil will usually reduce valve train noise
Old 08-16-2019, 02:34 PM   #5
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
Torco > amsoil
Old 08-16-2019, 03:04 PM   #6
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
...when hot.
When cold (startup), the opposite is true.
Old 08-16-2019, 03:58 PM   #7
oslouie
oslouie's Avatar
Drives: 2018 2SS M6 Redline
Wouldn't it cause more wear on the oil pump since it has to pump thicker oil?
oslouie is offline   Reply With Quote
Old 08-16-2019, 04:01 PM   #8
camaro5
camaro5's Avatar
Drives: X-15 Velocipede
Amsoil is an insider secret.
Nice cure for lifter tap.
Their gear oil, plus their additive can cure differential groaning as well.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 08-16-2019, 04:08 PM   #9
6spdhyperblue
Drives: 2SS 1LE
I don’t run thicker oil
Old 08-18-2019, 01:46 AM   #10
Kevin_S17
Kevin_S17's Avatar
Drives: 2017 2SS M6 Vert Summit White
Question for the OP - was your tapping noise only when the engine was cold? Did it go away as soon as your temp started to come up? I have a intermittent tap when cold but goes away as soon as the oil temp gets above 100F. Dealer says everything is ok.
2017 2SS M6 Vert Summit White; aFe CAI, E85, dyno tuned; Bigworm Graphix, various exterior mods
Kevin_S17 is offline   Reply With Quote
