Old 08-12-2019, 11:46 PM   #1
Jonathan2SS
Drives: 2016 Camaro 2ss
5th cylinder missfire
I got headers installed in my 2016 SS and got a 5th cylinder missfire code after a while. I installed new spark plug wires and it still seemed to missfire a little but no more CEL. Could it be a bad spark plug?
Any feedback is highly Appreciated
Jonathan2SS is offline   Reply With Quote
Old 08-13-2019, 03:45 AM   #2
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
Perhaps coincidental, perhaps not. I think you are on the right track. Perhaps when the headers were installed they did not remove the spark plugs and bumped one of them and cracked the core. I would definitely replace, or at least swap the spark plug with one from another cylinder and see if the problem moves.
I say coincidence because a failed injector can also cause a cylinder misfire which would have been unrelated to the header install. But I would start with the plug.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
