![]() ![]() ![]() ![]() ![]() Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Cons of 5mm spacer
What are the cons to adding a 5mm spacer?
Any spacer added to a wheel increases wear on wheel bearings by increasing torque on lugs at an increased distance.
Also need longer lugs usually. That's about it.
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
Bannable
I run 5mm at all 4 corners. No issues.
One must forego the self to attain total spiritual creaminess, and avoid the chewy chunks of degradation
2017 ZL1 A10 - Hyper Blue Metallic Rotofab CAI, TM ported TB, AWE non res touring catback with PLP's |
Just curious if there would be any complications using the spacer and drag racing. Car makes 620/650 to the wheel on Mustang Dyno. I know that not much compared to the 1000hp guy but wanna make sure things won’t just go boom by putting a load on the wheels with a 5mm spacer.
![]() Drives: 01 Z28, 1990 NASCAR Busch North Car Join Date: Jul 2018
Shifts under load
Drives: 2020 Camaro 1SS 1LE rally green Join Date: Apr 2017
Where did you buy yours? I'm thinking about getting some for the front.
HPDE - southeast - JTI- solo, PCA- blue. 22 Suzuki GSX-S 1000GT blue |
#7 |
![]() ![]() Drives: Camaro Z28 Join Date: Jan 2017
5mm hub centric spacers are completely safe to use on the factory wheel studs, there's enough thread engagement to not worry. As far as cons, they cost money and you have to install them, that's about it. You're not going to wear the front hubs out with them, a sticky tire will put more wear on the hubs than a small spacer like that will.
Also important to note that a wheel with a greater offset will also cause "wear" to the hub just as a spacer would. Once it's bolted to the car, the forces are pretty much equal assuming it's a hub centric spacer. There are a lot of professional race teams that run with spacers for various purposes. When using quality parts, there is nothing to fear. - Cory
JJ - Fitment Specialist /// Forged Wheels /// Wheels For Your Camaro
Camaro Wheel & Tire Fitment Guides /// Defining Real Performance /// Camaro Wheel Gallery expert@apexwheels.com |
