Old 08-07-2019, 07:17 AM   #1
warren3537
warren3537's Avatar
Drives: 2019 Red Hot ZL1 1LE: 2012 RAM 2500
SS dual exhaust rear diffuser
So after looking high, low and in-between with no success for an aftermarket diffuser for the dual exhaust, I have a factory diffuser on the way and need to know what kind of prep is needed, I plan on getting it painted gloss black but need some input just to make sure the paint will stick to it without flaking or chipping off.
warren3537 is offline   Reply With Quote
Old 08-07-2019, 09:34 AM   #2
anukula
Drives: Camaro 2ss
There are many after markets on ebay and youtube installs show they are very good fit. I found myself glossy black one for 165$
anukula is offline   Reply With Quote
Old 08-07-2019, 12:03 PM   #3
warren3537
warren3537's Avatar
Do you have the link.
Old 08-07-2019, 12:08 PM   #4
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Prime and paint. If the texture is a little rough, then some smoothing out may be necessary.
1hprush is offline   Reply With Quote
Old 08-07-2019, 01:03 PM   #5
anukula
Drives: Camaro 2ss
https://www.ebay.com/itm/For-2016-18...72.m2749.l2649
Old 08-07-2019, 01:06 PM   #6
DarkFangz1100
Drives: 2016 Camaro SS
As far as I know NOBODY makes a dual exhaust diffuser its always a quad...
DarkFangz1100 is offline   Reply With Quote
Old 08-07-2019, 04:24 PM   #7
warren3537
warren3537's Avatar
I did see one on eBay, but it was carbon fiber and waaaaaay to expensive.
Old 08-21-2019, 08:09 AM   #8
cmking26
Drives: 2018 Arctic Blue SS Recaro's
Yea Im in the same boat. I love my dual axle back and dont want to change to quad tips. So Im thinking of just pulling the stock diffuser off and painting it flat to match my other body mods. There's real no other option out there.
cmking26 is offline   Reply With Quote
Old 08-21-2019, 09:47 AM   #9
warren3537
warren3537's Avatar
Actually there is, I found a dual exhaust rear diffuser on eBay and got it for 145 bucks and I took it over to the paint and body shop not far from the house yesterday, and I am getting it painted gloss black for 223 bucks, once I get it back then I can put the car on the Quick Jack, pull the rear bumper off and replace it, I figure that I might as well do it right.
Old 08-21-2019, 01:19 PM   #10
cmking26
You have a link for the diffuser?
Old 08-21-2019, 04:28 PM   #11
warren3537
warren3537's Avatar
The diffuser that I found on eBay is the factory diffuser, once I get this one painted, I plan on selling mine.
Old 08-21-2019, 05:35 PM   #12
RLem619
RLem619's Avatar
Drives: 2019 Camaro 2SS A10
Wash with warm, soapy water
Dry
Wipe down good with a gray scotch pad (automotive, not dishes )
Rinse and dry
Wipe down with an anti-static agent or Tack Cloth
Spray light coats of a Plastic Adhesion Promoter ( 3 x )
Primer ( 3 x )
Base Coat ( 4 x )
Clear coat if desired (3 x )
* Spend the time in your prep work and save yourself the headache.
Scuff everywhere with the gray scotch pad, until a dull grayish.
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
RLem619 is offline   Reply With Quote
