![]() ![]() ![]() Drives: 2016 Camaro SS Join Date: Sep 2018
Radiator leak after Procharger install
Anyone else have this issue? My mechanic said it is super tight right where the charge pipe comes off of the intercooler and the radiator right there had to be moved. It is leaking from there and he is taking back apart but not sure how much room is left or what needs to be done. Was just curious to see if anyone else had run into it so I could pass the information along to him to speed things up, I am supposed to be in for tuning this morning but this is keeping me from getting it there and I had to wait two weeks to get in and I really don't want to have to reschedule and wait another two weeks.
![]() ![]() Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
what procharger did you go with? Sorry i might not be of any help but would like to hear the fix from those who have experienced this as well.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
Yep...another member did with a Maggie install. There are 2 different size bolts for the radiator bracket or something that your install guy removed, but he probably put the longer one back in the wrong spot and punctured the radiator.
I'll pass it along to my mechanic, thanks.
![]() Drives: 2017 50th Camaro SS Join Date: Jul 2016
No radiator leak but the belt cut into one of my AC hoses.
50th Anniversary Edition |Borla Atak and 60606 mid pipes| Kooks 1 7/8" | ProCharger Stage II |305/45/17 DRs | Circle D 3500 stall | LT4 fueling | Custom made Lowside Aux Pump | Alky Control Meth | DSX E85
#7 |
#8 |
![]() ![]() Drives: 2017 50th Anniversary 2SS Join Date: Sep 2016
When you relocate the aux radiator on the drivers side. Sometimes that hose doesn't get tightened properly. I had to pull my front fascia off and tighten that hose clamp a bit more back when I installed mine.
