Old 08-04-2019, 07:10 AM   #1
zepol9
Drives: 2016 Camaro 2SS NGM
Front seal replaced now new leak help please.
I didn't upgrade the fr main seal and blew it and upgraded to the ls3 cleaned all the oil off the car and now experienced another leak but i cannot figure from where, its not behind the balancer like the fr main. seems to be coming from around the starter area.?!? anyone with similar experience please chime in, putting her up on lift today. TIA
zepol9 is offline   Reply With Quote
Old 08-04-2019, 08:32 AM   #2
shinysun
Drives: 2016 Camaro SS
It would be the rear seal. You better check the piston failure, do the leak down test.
shinysun is offline   Reply With Quote
Old 08-04-2019, 08:54 AM   #3
zepol9
ah for real? blower has to come off?
Old 08-04-2019, 09:08 AM   #4
laynlo15
Drives: 2022 Lt1 A10
I blew front seal first, then replaced it with the ls3 and couple months late the rear seal. Then the carnage, number 1 ring land and then number 8 and she was smoking bad and dumping oil out the rear seal, bad enough I oil the track down for about a 25 minute cleanup and I had a belly pan diaper to catch oil if it happened, still enough came over the diaper and got on the exhaust. That sucked.
Old 08-04-2019, 09:38 AM   #5
zepol9
ah shit, no way to check with computer ? certain things im looking for
Old 08-04-2019, 10:01 AM   #6
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
compression test on all cylinders.
Old 08-04-2019, 10:03 AM   #7
shinysun
Almost no signs with scaner. Even my friend got 6 broken ring land out of 8, his car ran very well, except the blowbygas from the seals.
Old 08-05-2019, 08:59 PM   #8
Prochargedgen6
Drives: 2017 procharged camaro 2ss
How much boost were you running?
Prochargedgen6 is offline   Reply With Quote
Old 08-06-2019, 06:02 AM   #9
laynlo15
Mine ran well also but it dumped oil on the drag strip. That's not good and slicks really don't like it plus the wall is only about 10 ft away at over 140 mph or the guy in the other lane and the drag strip crew doesn't like the clean up either. If you do have broken ring lands its probably already damaged the cylinder walls. Compression check and have someone with a bore scope take a look down each of the cylinders.
Old 08-07-2019, 03:17 PM   #10
zepol9
I'm only running the 3.650 pulley so 8 - 9 lbs is all I have seen, going to bore scope the pistons and see if there is any damage to the walls. My technician friend said there would be white smoke if the motor is burning oil. I saw white smoke but I thought it's from it leaking out and hit the hot exhaust, will report back with the findings. Thank you all
Old 08-07-2019, 06:22 PM   #11
zepol9
now it has been noticed iats are running at 130
Old 08-07-2019, 07:05 PM   #12
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
Hardly abnormal...
Old 08-08-2019, 02:47 AM   #13
zepol9
Hardly abnormal...
now 156
Old 08-08-2019, 06:26 AM   #14
Joshinator99
Moderator
now 156
What’s ambient temp? What are the conditions for that reading (WOT, for how long, etc)? Number of factors go into that.
