Old 08-03-2019, 10:18 AM   #1
64stingray
Drives: 64vette,2010 2SS,2013 Zl1
ZL1 addons
I just got my 2019 zl1 and I got some zl1 addons to facilitate jacking the car but something I'm not sure of, the slot in the addons where the weld fit into is deeper than the weld so when jacking, the whole pressure is on the floor on each side of the weld and none on the weld itself, is that the way it's suppose to be.
64stingray
64stingray is offline   Reply With Quote
Old 08-03-2019, 10:28 AM   #2
ZL1 BRAVO
Drives: 2017 ZL1
Yes, along as you have them where they're supposed to you'll be fine.
ZL1 BRAVO is offline   Reply With Quote
Old 08-03-2019, 11:08 AM   #3
PROMETHEUS
PROMETHEUS's Avatar
Yep.
Old 08-03-2019, 11:22 AM   #4
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I bought them but have not used them yet. I was thinking on leaving them on all the time, but my luck I would lose one.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 08-03-2019, 11:27 AM   #5
Hell Raiser
To fast is not enough
Hell Raiser's Avatar
Drives: 2019 ZL1 Camaro & 2020 CT5-V Turbo
I put them on and so far they stayed. 6 months now.
Hell Raiser is offline   Reply With Quote
Old 08-03-2019, 11:28 AM   #6
ssrallyred
ssrallyred's Avatar
Drives: 2017 Summit White ZL1 M6
I have had mine on for two years and 11K miles and had no issue with one or more coming off. I check the set screws from time to time but they are never loose.
Roto Fab/ Kook's LT's,ported blower,removed lid baffle/ 103mm TB' lower pulley and tune.
651/660.
ssrallyred is offline   Reply With Quote
Old 08-03-2019, 12:46 PM   #7
Markoz28
Drives: 18 ZL1 nightfall grey A10
Had mine for 4K miles and used them several times with no issues. I do check if they are loose every time tho. I’ve only retorqued once after driving the car about 10 miles with them on just to be safe.
Markoz28 is offline   Reply With Quote
Old 08-03-2019, 02:12 PM   #8
Allez
Allez's Avatar
64stingray
According to ZL1 Addons it is supposed to contact the weld itself, not the floor on either side. Are you sure you have the right ones? I realize this is for the jackpad, but regardless it looks like it should sit on the pinch weld itself.
Allez is offline   Reply With Quote
Old 08-03-2019, 02:46 PM   #9
Marcedward_907
Marcedward_907's Avatar
Drives: 2018 Camaro ZL1 Summit White
Mine have been on since day 1 , April of 2018.
I did put a little dab of blue loctite on the set screws and have not had to tighten them or touch them. Hope that helps.
Marcedward_907 is offline   Reply With Quote
Old 08-03-2019, 03:09 PM   #10
I just use the magnetic one with puck.
It lifts both front and rear tires at the same time.
Old 08-03-2019, 04:01 PM   #11
PROMETHEUS
PROMETHEUS's Avatar
Blue Loctite on my set screws as well, and have not any retighten issues.
