Old 08-03-2019, 08:58 AM   #1
Alex74
Alex74's Avatar
Drives: 2018 NFG SS 1LE
Dash Cam Hardwire w/ Gen5DIY harness
I was looking for a clean way to install my front facing Rexing dash cam. I'm not fussed about a parking mode, I simply want the cam recording when the car in use. I really did not want to mess around trying to tap into the fusebox.
When I wired my wife's minivan dash cam, I power-tapped the rearview mirror and that made for a really clean / easy install.
Looked for a similar solution for the Camaro, and took a look at what Gen5DIY had; the closest I found was the radar detector/gopro harness.
https://www.gen5diy.com/products/16-...52668dde&_ss=r
Asked the team over at Gen5 if they could suggest a solution, and they said they could modify that harness to delete the radar detector wire.
Perfect.
Gen5 did a really quick job of working the order. The customized harness cost $64.99 shipped. Considering I'm paying for someones time as well as the harness, I'm fine with that for the solution I was after.
The install was as easy as this video makes it look:
https://www.youtube.com/watch?time_c...&v=7QH9JiNiT1o
My own photos of the install are shown below. All the wiring tucked nicely into the headliner.
I spent less than 15 minutes on this, and would have been even quicker if I hadn't watched the install video a few times just to double-triple check I was doing things right.
Very happy with this solution. Thanks to the guys over at Gen5DIY - quality service and product!
Alex74 is offline   Reply With Quote
Old 08-04-2019, 11:56 AM   #2
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
That is super neat and easy.
Do you know what fuse that circuit is on?
overdriv is offline   Reply With Quote
Old 08-04-2019, 04:30 PM   #3
Alex74
Alex74's Avatar
I honestly don't know.
I'm not even sure how the harness taps the power lines to output the 5V, all I know is that it works
Old 08-04-2019, 11:58 PM   #4
overdriv
overdriv's Avatar
The little white box is the step down transformer.
I am probably anal, but I wanted my camera on a fuse of it's own. I piggy backed onto a 20 amp circuit. My cam requires a 2A fuse.
Not trying to suggest anything is wrong with your way at all. Very clean and a hell of a lot easier.
Old 08-05-2019, 07:19 PM   #5
Alex74
Alex74's Avatar
Ah, understood - cheers!
Old 08-09-2019, 09:39 PM   #6
Ebbsnflows
Drives: 2018 Camaro ZL1-1LE
I need this EXACT configuration. I also have a Rexing camera that I want to hardwire. I'm gonna email them 1st thing Monday morning.
2018 Camaro ZL1/1LE
Ebbsnflows is offline   Reply With Quote
Old 06-15-2020, 03:58 PM   #7
Operator09
Drives: 17 2SS Camaro
Had any issues with the harness??
Operator09 is offline   Reply With Quote
Old 06-15-2020, 06:02 PM   #8
Bumbleboy92
Long hauler
Bumbleboy92's Avatar
Drives: 2022 Camaro 2SS 1LE
I actually bought it from him, currently using it for my Aukey DR02D without issue. Supplies power on engine start and cuts off when the Engine is stopped, works like a dream
2016 1LT v6
- Totaled
Happiness: Infinite
