![]() Drives: 2018 ZL1 1LE - HBM, PDR Join Date: Jun 2017
Exhaust decibel levels - different exhaust combinations
I thought I would share some sound meter readings for inquiring minds. My car has gone through several iterations of exhaust combinations. Early on I replaced my stock NPP exhaust with a Borla 3" cat back exhaust. I deleted the secondary cats but kept the primary cats. Stock exhaust manifolds and stock primary cats. This represents Scenario 1.
Then after some additional power mods, I needed better flow. I kept the exhaust manifolds stock but ported and opened up the collector outlet. I also deleted the primary cats. I was afraid this would be too loud and so I went ahead and welded in some 3" Vibrant resonators just before the Borla X-pipe. This represents Scenario 2. After getting the car up and running under Scenario 2, I really liked the exhaust sound but it was just too loud and would cause too much attention. Not good. So I removed the Borla NPP mufflers (axle back) and replaced it with the factory NPP suitcase muffler. This is Scenario 3. All sound measurements taken at 19.5" away from outer-most exhaust tip at same height and 45 degree angle off to the side. Scenario 1 (Borla S-Type CatBack w/stock manifolds & secondary cat delete) Cold start - 115 db Warm start - 102 db IDLE Ice - 77 Tour - 77 Sport - 79 Track - 79 2500 RPM Ice - 93 Tour - 93 Sport - 93 Track - 93 3250 RPM Ice - 98 Tour - 98 Sport - 98 Track - 98 4000 RPM Did not take measurement at this RPM range Scenario 2 (Borla S-Type with Vibrant resonators, ported stock exhaust manifold & no cats) Cold start - 111 db Warm start - 111 db IDLE Ice - 89 Tour - 89 Sport - 91 Track - 91 2500 RPM Ice - 103 Tour - 103 Sport - 103 Track - 103 3250 RPM Ice - 108 Tour - 108 Sport - 108 Track - 108 4000 RPM Ice - 116 Tour - 116 Sport - 116 Track - 116 Scenario 3 (Factory Suitcase muffler, Vibrant resonators, ported stock exhaust manifold and no cats) Cold start - did not take Warm start - 84 db IDLE Ice - 83 Tour - 83 Sport - 85 Track - 85 2500 RPM Ice - 98 Tour - 98 Sport - 98 Track - 98 3250 RPM Ice - 101 Tour - 101 Sport - 103 Track - 103 4000 RPM Ice - 108 Tour - 108 Sport - 109 Track - 109 ![]()
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
Last edited by TMS; 12-12-2019 at 06:45 PM. Reason: Added descriptions to scenarios |
![]() Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
Thanks ! I have the borla Atak cat back scenario #1, So that means mine is even louder ! I try to keep a low profile in mine, I have seen people jump when the rev match kicks in ! I stay below 2 grand, but I let her rip in the back woods ! It's good to be in Texas ! LOL !
aka BeastZL1
Drives: 2019 Camaro ZL1 1LE, 2004 Cobra Join Date: Dec 2017
Thanks for posting the data like this! I'm a Mechanical Engineer and this is great.
![]() ![]() Drives: 2019 ZL1 1LE A10 Join Date: Jan 2015
Any video? would be greatly appreciated.
Ryker #29
2019 ZL1 1LE A10 2015 Z/28 #809 |
![]() Drives: 2018 Chevrolet Camaro ZL1 Join Date: Jun 2018
Thanks for sharing, a couple of questions:
- Were the readings in scenario 3 with the NPP valves open? - Did you notice a significantly different tone between Scenario 1 and Scenario 3, or, just volume? - How long of resonator did you use? |
#7 |
I have some videos hosted. I’ll post them here. I was wrong. No sound clip videos of latest setup. All I have is the factory stock video clips and then the Scenario 1 video clips. It likely won't help you but here is the thread link: https://www.camaro6.com/forums/showthread.php?t=530016 I do have a walk-under video clip (no sound) that shows Scenario 3 setup. Here it is: https://youtu.be/60YLmqvGWDk
#8 | |
All Scenarios were taken in the each of the 4 various modes. NPP valves operate differently in each of those modes. Tone between 1 and 3 is different. Scenario 3 is more like stock but louder and it gives some Rice Krispies effect on the decel. Although scenario 3 sure brings out the stink. As well as Scenario 2. Scenario 1 runs louder on highway at light throttle than scenario 3. 3 is much more stealthy like stock until you open the throttle up a bit and then it gets its noise on. I used the 12 inch. Would have gone for the 18” if I had a do over although it would be a tight fit leading into the X-pipe.
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 C6Z06 Join Date: Nov 2016
Can you throw the Borla back on so we can see the difference just between suitcase and Borla without any cats in the mix?
#10 |
Life's Short, Live Fast!
Drives: 2017 Hyper Blue A10 ZL1 Join Date: Nov 2016
He did that. It's the difference between scenarios 2 & 3. He only had cats in scenario 1.
Full exhaust, lower pulley, E35 -10.36 at 133 mph 690 DA straight from the street with a slight spin at launch. TZQPHG '17 ZL1 HBM|A10|Nav|PDR|CFW Hood|ZL1 Mats 12/26/2016 Ordered! 2/8/2017 Built!! 3/2/2017 Brought Home!!! |
#11 |
#12 | |
TMS, did you happen to take measurements of the stock collector? I've heard it's only 2". Can you confirm?
#13 | |
Yes, I recall it is right at 2". Also, there is enough cast material to port it out at least and additional 3/8" which is what I took it too. Also updated post #7 with videos.
#14 |
Thank you! Really good thread. Love all the details and measurements.
