Old 08-01-2019, 09:06 PM   #1
SGDM
SGDM's Avatar
Drives: 2016 2SS
A8 Quit Today
I was cruising at 60 mph in D and rpm spiked, I let off throttle, rpm settled, pressed throttle and nothing. I coasted into parking lot, popped hood, checked underneath-no fluid, nothing in engine bay. I ran diagnostics on Dash Command and no codes. 15,100 miles on car. I checked trans temp - 150 deg. Turned car off, started car and tried D, R, and manual. No go...
Any suggestions??? Ugh!
Who Dares...Wins
SGDM is offline   Reply With Quote
Old 08-01-2019, 09:19 PM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
My first guess would be that the pump failed (broken chain?), but I would expect that should throw a code.
Old 08-01-2019, 09:48 PM   #3
oldman
Drives: SS 6 speed of course
Is it making noise, maybe a shaft failed. bummer these A8 pretty strong.
Old 08-01-2019, 09:59 PM   #4
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
I’ll leave this here, just in case...!
https://mxamotorsports.com/product/m...ho-spec-build/
Old 08-01-2019, 10:00 PM   #5
SGDM
SGDM's Avatar
Drives: 2016 2SS
No noise, a bit of a shudder then it quit.
Who Dares...Wins
Old 08-01-2019, 10:02 PM   #6
SGDM
SGDM's Avatar
Drives: 2016 2SS
Thanks brother...
Who Dares...Wins
Old 08-01-2019, 10:30 PM   #7
SSport16
SSport16's Avatar
My crapped out of me 2 years ago...started with no shifting out of 1 st gear on the way to the dealer. I literally pulled into the dealers garage bays, they couldn't get it into D or R, $3000k in parts and labor that GM paid under warranty, basically was rebuilt.
Old 08-04-2019, 05:12 PM   #8
SGDM
SGDM's Avatar
Drives: 2016 2SS
It was the TQ converter and pump.
Who Dares...Wins
Old 08-04-2019, 07:09 PM   #9
Joshinator99
Moderator
What did you end up replacing the TQ converter with (stock or aftermarket)? Glad to hear you’re back up and running.
Old 08-04-2019, 11:41 PM   #10
SGDM
SGDM's Avatar
Drives: 2016 2SS
Thanks man. Stock replace and all covered by GM. The car is sold...
Who Dares...Wins
Old 09-07-2019, 02:25 PM   #11
s346k
s346k's Avatar
Drives: like an old lady
that escalated quickly.
Old 10-09-2019, 05:05 PM   #12
ZarusSS
Drives: Chevy Camaro
So from 8/1 to 8/4 the car broke down was fixed then sold?
ZarusSS is offline   Reply With Quote
