Old 07-28-2019, 11:39 AM   #1
Sham2SS
Drives: 2016 Summit white 2ss
HPTuners Issue
If anyone has experience with HPTuners i'm having an issue where my MPVI2 isn't recognized with any devices. I used it in the past to tune my vehicle but now i'm trying to load another on and my PC will not recognize that there is an MPVI Interface connected. I've tried several different USB C cords as well as 3 Different laptops to try and see why it will not connect. Not having any luck here and want to try and get this resolved. Could my actual MPVI2 just be bad at this point? I've only really used it a handful of times and it has just been sitting plugged into my OBD2 since my original tune.
Sham2SS is offline   Reply With Quote
Old 07-28-2019, 12:47 PM   #2
TJay74
Are you trying to use it via BT or via the USC-C cable? have you checked to see if the firmware is up to date, I think there has been several updates pushed out for the MPIV2.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 07-28-2019, 12:51 PM   #3
Juiced1
Drives: 2012 2SS CAMARO 45th
Try to update the software and also reload your application key.
Juiced1 is offline   Reply With Quote
Old 07-28-2019, 01:07 PM   #4
Sham2SS
Firmware is up to date, all the drivers and software are up to date as well, when i get home from work ill take some screen shots of the program and post them
Old 07-28-2019, 01:25 PM   #5
Sham2SS
USB-C cable.
tried several different cables and 2 laptops
Old 07-30-2019, 12:58 PM   #6
thebanks06
thebanks06's Avatar
Drives: 2016 Chevy Camaro 2SS
I've only had the problem if I had the vcm scanner running at the same time
thebanks06 is offline   Reply With Quote
Old 08-01-2019, 09:13 AM   #7
TJay74
Yep, correct. You cant flash a tune if the VCM scanner is connected to the car. You have to disconnect the VCM scanner before you try to flash a tune.
