Old 07-28-2019, 09:20 AM   #1
H(.)(.)ters
H(.)(.)ters's Avatar
Drives: 2SS - Black
ProCharger D1X and mystery squeak
I had my 2016 2SS fitted with the ProCharger D1X kit with TiAL Racing BOV last year by Horsepower Solutions in Newport News, VA. Car was tuned by Josh Tonski and runs great as my daily driver. It’s been over a year and I can’t figure out why my car makes this little squeak at slow speeds whenever lifting off the gas pedal. It only happens when the weather is mostly humid and above 90 degrees. In the fall and cooler months, there is no squeak at all.
Have any of you all experienced anything like this? Attaching link to YouTube video for reference. The squeak is very faint, so listen closely. Thanks for any input. I appreciate it.
https://youtu.be/N82S8zbpWiU
Procharger D1X
Kinda fast, I guess
H(.)(.)ters is offline   Reply With Quote
Old 07-28-2019, 09:36 AM   #2
NYblack1le
Drives: 2018 1SS 1LE
Can you recreate the sound when stationary?
NYblack1le is offline   Reply With Quote
Old 07-28-2019, 09:58 AM   #3
H(.)(.)ters
Drives: 2SS - Black
Yep. But not consistently.
Procharger D1X
Kinda fast, I guess
Old 07-28-2019, 12:46 PM   #4
TJay74
I am gonna say belt slip. Have you adjusted the belt tension?
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD
Old 07-28-2019, 05:08 PM   #5
H(.)(.)ters
Drives: 2SS - Black
I have not adjusted the belt. How do I know it’s slipping? Is it hard to adjust? Any tutorials out there?
Procharger D1X
Kinda fast, I guess
Old 07-29-2019, 06:57 AM   #6
Dysan911
Dysan911's Avatar
Drives: 2017 50th Anniversary 2SS
Of course while the car is off. Reach down and grab the longest section of the belt between the upper and lower pulley. Grab About half way and see how far over the belt will twist. I set mine so so that it's pretty tight enough that it can't roll back over on it's self past 90 degrees.
There are also notches on the tensioner as well. Procharger usually has a mark on one of those that they recommend you start off on.
Dysan911 is offline   Reply With Quote
Old 07-29-2019, 07:21 AM   #7
95 imp
Dumb Ass Deluxe
Try a can of belt dressing if the belt isn't loose.
Old 07-29-2019, 06:02 PM   #8
H(.)(.)ters
Drives: 2SS - Black
Got any pics or vids to use as reference?
Procharger D1X
Kinda fast, I guess
Old 07-29-2019, 07:05 PM   #9
oldman
Drives: SS 6 speed of course
my D1x sounds like an old pencil sharpener for what its worth the P1 sounded great...
Old 07-29-2019, 08:18 PM   #10
Dysan911
Dysan911's Avatar
I believe the procharger install manual also has a photo reference regarding the belt tightening as well.
Old 08-01-2019, 09:11 AM   #11
TJay74
If you have not adjusted the belt since the install then it will more than likely be belt slip. The belts stretch some over time.
Old 08-01-2019, 07:07 PM   #12
H(.)(.)ters
Drives: 2SS - Black
I have never adjusted the belt. The squeak/whistle started happening almost 6 weeks after initial install last summer. Is that normal? It went away last fall and winter and returned like clockwork around May of this year. I always figured that I would feel some kind of jerkiness with the boost if the belt was slipping. I just don’t know from lack of experience.
I was mistaken on being able to reproduce the sound at a standstill. I tried with no luck. Also, I tried to invoke the squeak 2 days ago in 70-75 degrees with no luck. But, today in 90 degrees I could make it chirp like a bird. So weird.
I will dig up the manual and see how to adjust the belt.
Procharger D1X
Kinda fast, I guess
Old 08-01-2019, 08:50 PM   #13
oldman
mine has a chirp chirp sound like maybe the impeller is hitting sumting... but I've check and it is fine, perfect even. IMO the D1x just does not sound as good as the Ps
