Old 07-25-2019, 10:59 AM   #1
Vigilante375
Drives: 2018 Camaro ZL1
Rear rotor and pad issue
I went to the dealership for my last free oil change a while back and I've been trying to find out if what they are saying is true. If anyone who drives their ZL1 on dirt roads could chime in, I'd appreciate it. This is one a 2018 ZL1 A10.
The rear rotors have some scoring done to them and the rear pads are down to 4mm thickness while my front rotors are good and the pads are at 7mm thickness. This was brought up to me by the service person.
The service person said it must be from me driving on dirt roads. I do drive on 2 miles, one way, fairly often. I was also informed that this wasn't covered under warranty so they would charge me around $850 to replace both rotors and pads. Of which I declined and found all the parts needed for under $300 and 30 minutes or so of my time.
Now how can my front rotors and pads be fine but not the rear? Is this from the dirt road or something else? I feel this should be covered under warranty since my car is not even a year old but I'm trying to see what anyone else has seen on an issue like this.
One other thing, I changed my oil myself around 1500 miles. The dealer changed it'd 5k miles later (~5500 miles) and nothing was wrong with the pads at that time. 5k miles (~10500 miles) after that is now when this issue was brought up. I autocrossed the car once before 5500 miles.
Old 07-25-2019, 11:02 AM   #2
Dave-ROR
Drives: A few
I would assume near constant traction control intervention if it uses the rear brakes instead of just cutting power. Not sure what the TC methodology is on these cars though.
-Dave
HPDE/DD: 2018 Camaro ZL1 1LE || HPDE/DD: 2015 Subaru BRZ ||Tow Vehicle: 2004 GMC Sierra 2500 8.1L || Weekend toy: 1994 MR2 Turbo || The other weekend toy: 1993 MR2 Turbo || Track car: 1998 Integra Type-R || Race car: 1996 Integra GS-R || New race car build: 1992 Honda Civic Hatchback
Too many cars.. never.
Dave-ROR is offline   Reply With Quote
Old 07-25-2019, 11:27 AM   #3
closs2sx
closs2sx's Avatar
Drives: 1970 chevelle
What dave-ror said. if you don't turn traction control off every time the car senses wheel slip its using rear brake to stop it. I turn all the nannies off when I drive my car because of this. My 1970 chevelle doesn't have any of that and it was the car i learned to drive on and I'm still here thank god
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car
2015 Z06 Z07
Daytona Sunrise Orange Metallic
Dads Car
2013 ZL1 vin 963
Crystal Red Tint Coat/Black Wheels
Exposed Carbon Fiber Insert
6 Spd Manual
closs2sx is offline   Reply With Quote
Old 07-25-2019, 12:19 PM   #4
collinms
Drives: 2017 ZL1 A10 Summit White
If you ran in PTM modes this wouldn't be an issue. Run in dry mode or sport 1 for street. Simply running in sport mode and driving aggressive is not the right mode in my opinion.
collinms is offline   Reply With Quote
Old 07-25-2019, 03:43 PM   #5
Dave-ROR
Drives: A few
Huh? Did you mean to reply to me? I was commenting on his dirt road driving causing TC to activate nothing about driving aggressively.
-Dave
Old 07-25-2019, 04:14 PM   #6
radz28
Petro-sexual
radz28's Avatar
Drives: Ultra-Grin
It used to be that some GM cars (Toyota, too, that I can recall advertising about) used a brake-force distribution system that would favor the rear brakes more than the front under regular driving so the amount of wear, from front-to-rear, would equalize a little. So it would bias the rear brakes more than the front - because the front do most of the work. I'm not sure if GM still uses that strategy...
'20 ZL1 Black "Fury"
Old 07-25-2019, 05:31 PM   #7
s.hammer
Drives: 2015 Z/28
If your car has PDR, try recording your usual driving routes to see if traction control is intervening. I just did rear pads on mine, but the rotors are smooth with no issues. Have also gone through a set of fronts so it is odd to wear out the rears first.
s.hammer is offline   Reply With Quote
Old 07-25-2019, 05:41 PM   #8
Vigilante375
I always drive on the dirt roads with traction off. So that shouldn't be an issue. Seeing as I may go 30 at most. TC intervention on a dirt road actually hinders you because you need to keep forward momentum.
I use TC every where else. Im confident in driving but I'll let the nannies help me when it's raining or a little slippery out.
I guess I'll just replace the pads and see what happens. Thanks for the input guys.
Old 09-01-2019, 01:44 AM   #9
rodrig7521
2014 1LE
rodrig7521's Avatar
Drives: 1le
Looking to buy this Zl1 1le, do you guys think the rotors needs to be replace soon ?
rodrig7521 is offline   Reply With Quote
Old 09-01-2019, 05:36 AM   #10
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
Hard to tell by pictures. Take a vernier caliper and measure the rotor thickness you can also feel the rotor surface for any ridges and check to see if any spider cracks have started to appear on the rotors.
SWZL11LE is offline   Reply With Quote
Old 09-01-2019, 09:43 AM   #11
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
I would replace both, rotors and pads, if for nothing else, peace of mind.
1hprush is offline   Reply With Quote
Old 09-01-2019, 02:19 PM   #12
Deakins
Drives: 2017 2ss, m6
If there are no cracks out to the inner or outer edges run them. Those look to have had some heat in them but it's nothing compared to what a set will look like after a full on 40 min stint with a real race pad in them.
Deakins is offline   Reply With Quote
Old 09-01-2019, 06:46 PM   #13
kramard
Drives: 2012 BMW 135i
This ones been tracked hard. I recall looking at this car on fb a few mo ago. Whoever tracked it knew what they were doing. I’m a monster on brakes with 6 track days and I don’t have discoloring like that. I’m JUST starting to get that discoloration ring. I would swap pads and brakes on that car ASAP. Unless the price is right you’ll probably find a less tracked zle without looking too much.
kramard is offline   Reply With Quote
Old 09-02-2019, 12:07 AM   #14
rodrig7521
2014 1LE
rodrig7521's Avatar
Drives: 1le
yea that's what i was thinking they want 56,900 for this one. It only has 11K miles which is low but its been pushed hard. maybe i will pass on this one. Thanks everyone for the information.
