![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Mosaic Bk ZL1 M6 Join Date: Jul 2009
Oil Life Monitor
Anyone else get this questionable data on their oil life or can explain it? I'm at odds with how it can go from 97% to 51% in 2 weeks and 115 miles. No track days, just highway miles. Did the same thing last year. 97% to 26% also seems excessive for 2300 miles. ( I realize time is part of the algorithm) 2000 of that was 2 road trips. I put 3-4k miles on this car per year and change it once when putting away for winter. When it got to 9% last September I just reset it. I see no reason not to do that again soon.
Also, FWIW, I have a 2016 Silverado that my wife drives with 1850 miles on it that the oil gets changed once per year and the monitor doesn't behave this way.
![]() ![]() ![]() ![]() Drives: 2019 ZL-1, Shadow Gray, Sold Join Date: Jan 2019
Seems right to me, you are about to come up on 3K miles since you last change. Plus you have gone over 9 months since that oil change. The oil life monitor works on both mileage and time.
![]() Drives: 2016 Camaro 2SS Join Date: Sep 2015
Yep...mileage and time. I noticed the same thing...put car away for winter at 100%...first reading after i get it out is the same as i put it in...100%..then next month report...it drops a lot based on the amount of time that passed in storage...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
![]() Drives: 2017 ZL1 Join Date: Nov 2009
I have a 2017 and it gets to a very low percentage when it gets close to the anniversary date that I bought it regardless of mileage every year. I changed it the first time at 1,367 miles and the second time at 2,460 miles a year later. I don't drive it very often and notice the percentage drops very quickly when I do take it out. The oil comes out looking new. It stays in a climate controlled basement so it looks like to me it measure time rather than mileage.
Yep, I agree with what you guys are saying, except this wasn't an issue with my 2010 SS LS3 or 2013 ZL1. Is it that LT motors are more susceptible to this than LS motors?
![]() ![]() ![]() Drives: 2018 ZL1 Camaro 6M Red Hot Join Date: Aug 2013
I would be more willing to believe it is GM just wanting you to come to the stealership more often.
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
#7 |
Drives: 2018 ZL1 1LE Join Date: Jun 2012
#8 |
Its a combination of both...max % is going to be 12 months...if you never drive car...it will lose 8.3% every month. I usually get mine changed in the 10th month (never get close to needed changed based on low miles i drive). If you let it get below 10%, you have to acknowledge the message in display at every start up or it wont go away..PITA
#9 |
Thanks guys. Based on 26% with 3 months to go since last oil change I agree with above. 8%/month is likely the minimum per the present algorithm. I'll just reset it if it gets below 10% before then, which last year was within a month of previous change.
#10 |
![]() ![]() ![]() ![]() Drives: 2018 Camaro ZL1 Join Date: Aug 2018
I pay no attention to the oil life monitor. I only pay attention to the mileage. I changed my oil at 4000 miles then my oil isn't ready to be changed again until 9000 miles. Unless I go to a track day then it'll be a different story.
There's just too much extra stuff in cars that manufacturers put in these days. Im honestly surprised the ZL1 doesn't have a brake pad monitor. My 135i had one and that's one thing I wished the ZL1 had. |
#11 |
![]() ![]() Drives: 2015commemorative vert 2SS Join Date: Oct 2013
I know when I bought my ZL1 from a dealer in michigan, it sat from december of 17 to march of 18 with only 150 miles on it. The oil life moniter was down to 23% when I checked it. So more about time than miles obviously.
So when I told the sales guy about it, he advised me to just push the reset button, not change the oil.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded 2015 commemorative vert 2ss |
#12 |
![]() Drives: 2019 ZL1 1LE Join Date: Jan 2019
Funny I've been "hot-wiring" them on our Range Rovers for years...essentially disabling the sensors by splicing the two wires together when I do our brake jobs. I don't like buying new ones (even though they're cheap) and I don't mind checking the pads when I'm rotating tires. Something about them pisses me off...I think I might be strange but whatever!
#13 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#14 |
I do 12-13K per year, oil get's changed in the Fall, and then in the spring...6 month intervals...no care what the life meter says. I do think that this one falls more rapidly than my Mustang GT did.
