Old 07-23-2019, 06:16 PM   #1
cskipgo
cskipgo's Avatar
Drives: 2019 2SS A10 Shadow Gray
Exhaust Whistle after cold start
Hello!
I have a 2019 SS with NPP exhaust. It started making a whistle (almost a metal on metal sound). It happens about 7-10 seconds after starting it in the morning? Sometimes it happens on the freeway. It seems to coincide sometimes with the change from V8 to V4. But consistently happens after a cold start. I am thinking it is the exhaust valves closing?
Anyone else have this issue?
cskipgo is offline   Reply With Quote
Old 07-24-2019, 07:44 AM   #2
jimharrell
Drives: 2023 Camaro 2SS 1LE
What mode is it in? Track?
2023/2SS/1LE/Riverside Blue Metallic/M6/PDR/NAV/Red Seat Belts/Sport Alloy Pedals/Wicker Bill Spoiler/Black Sueded Knee Pads/Black Wheel Lug Nuts and Locks/Black Camaro Fender Badge Emblem
1100 - 3/14/23
2000 - 3/14/23
3000 - 3/15/23 TPW 4/10/23
3400 - 4/03/23 TPW 4/10/23
3800 - 4/07/23
4200? - 4/12/23
jimharrell is offline   Reply With Quote
Old 07-24-2019, 09:38 AM   #3
cskipgo
cskipgo's Avatar
I usually keep it in Sport, but I tried starting it in Tour and same thing. Maybe I should try starting it in Track, does the mode effect the initial start up?
Old 07-24-2019, 11:01 AM   #4
cskipgo
cskipgo's Avatar
Also, dealer kept it for a week. Said they needed to consult with a regional service technician manager? They gave me a loaner for the week, said GM does not have a fix at this time. I just got it back. Oddly, my paperwork states "Customer reports exhaust noise, no abnormal noise heard"?
They state they will contact me if GM offers a fix at some point. Is this normal? Should I be concerned that my paperwork does not state that they heard the noise?
Old 07-24-2019, 11:10 PM   #5
Calcanuck
Drives: 2017 Hyper Blue 2SS
My 2017 has a similar noise and has since new, it does not last long so I have never taken it in to get it checked out.
Calcanuck is offline   Reply With Quote
Old 07-25-2019, 07:25 AM   #6
jimharrell
I have the same kind of car, never noticed anything. The mode does affect startup...I believe though that Tour, Sport, and Track are all the same for the startup, that Stealth is the only one that keeps the valves closed on startup but I could be wrong.
1100 - 3/14/23
2000 - 3/14/23
3800 - 4/07/23
4200? - 4/12/23
Old 07-25-2019, 08:07 AM   #7
Wyzz Kydd
Drives: 2018 Camaro SS1 1LE
I don't believe you will be able to start it in Track mode. If you turn it off while in Track mode it will default to Touring when you next crank it up. You can leave it in either Touring, or Sport and it will stay there when you next start it.
Wyzz Kydd is offline   Reply With Quote
Old 07-25-2019, 08:58 AM   #8
jimharrell
If you're talking the driving mode, yes, but if you go into the menus and select Track for exhaust, it always stays in Track for the exhaust!
1100 - 3/14/23
2000 - 3/14/23
3800 - 4/07/23
4200? - 4/12/23
Old 07-25-2019, 11:28 AM   #9
Wyzz Kydd
That's true. I should have remembered that since my exhaust is locked into Track.
Old 07-26-2019, 02:43 AM   #10
Biscuit.fr
Drives: Red hot ZL1 A10 2017
If you are looking for NPP sound issues
Look at that:
https://static.nhtsa.gov/odi/tsbs/20...82403-5448.pdf
May be not related, but just in case...
Biscuit.fr is offline   Reply With Quote
