Old 07-23-2019, 05:29 AM   #1
PROMETHEUS
PROMETHEUS's Avatar
Windshield Issue
Morning Everyone,
I was hesitant to post this, put at this point I have no idea what to do to get this glass, smudge free.
As you can see by the pics, there is a film of smudge on the windshield. I have tried everything to get this off. Multiple types Glass Cleaner, Soap&Water, 0000 Steel Wool, Vinegar&Alcohol, Razor Blade. At first I thought it was the microfiber rags were contaminanted, so I used brand new ones, then paper towels, then newspaper. Nothing seems to touch it. I have even had my "clean freak" wife take a crack it. When I run my finger across, both on the inside and outside, nothing happens to the smudges.
I am aware of the out-gasing from the interior plastics, but I have always been able to remove that. I thought the glass in my Corvette was a Pain in the Axx, but this is crazy.
At this point, I am beginning to believe it is defective glass, but that seems far fetched. Before I take it to the dealership, I wanted to ask, if anyone else have experienced this and/or have a fix. Thanks in advance.
Old 07-23-2019, 05:35 AM   #2
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
0000 steel wool?!
Take it to a professional detailer. If you scratched it, then they'll need to polish it. If they don't need to polish, they'll know how to get it clean. Experience matters.
Old 07-23-2019, 06:00 AM   #3
PROMETHEUS
PROMETHEUS's Avatar
0000 Steel Wool will not scratch glass!
Old 07-23-2019, 09:57 AM   #4
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
You already tried polish right, something finer than rubbing compound like scratch remover?
If that doesn't do it you have a defective windshield, that's very weird.
SFV1LE is offline   Reply With Quote
Old 07-23-2019, 10:01 AM   #5
BAD MOOOFOOO
Drives: between cars
Try a Mr. Clean Magic Eraser.
BAD MOOOFOOO is offline   Reply With Quote
Old 07-23-2019, 10:20 AM   #6
PROMETHEUS
PROMETHEUS's Avatar
Update
I took Mequiars's Scratch remover 2.0 and whatever it was on the windshield...…..it took it off! I got about 90 percent of it off "all on the inside" by hand. Worked on it for about 2 hours.
Compounded the outside with my DA and subsequently sealed it with Adams Windshield Sealant. Thanks for the assist guys!
Old 07-23-2019, 10:22 AM   #7
JD2018_ZL1
Drives: 2018 ZL1 Camaro
Looks like you need to use a solvent of some kind. Amazon also has a good glass polishing system. if it doesn't come off then it could be an issue in the glass itself. I know I couldn't live with that.
JD2018_ZL1 is offline   Reply With Quote
Old 07-23-2019, 10:46 AM   #8
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
Clay bar the windshield with lots of lube. The clay will remove all the grime. Also, coat it with Rainex or glass wax afterwards.
Clean your wipers - glass cleaner does a good job.
Discard the wiper fluid in the tank.
viurniel is offline   Reply With Quote
Old 07-23-2019, 03:43 PM   #9
DangerZL1
Drives: 2023 Black ZL1 Auto
Wow. That was some serious out gassing of the dash, or whatever it was. Glad it came off.
Old 07-23-2019, 08:28 PM   #10
mblum
Drives: 2017 ZL1 Camaro
I second the clay bar, just dont use it on paint once used on glass to ensure any containments the bar picks up wont scratch the paint. This also works very well for hard water spots on glass.
2017 Garnet Red ZL1 A10
Other Rides, 97 Trans Am, 72 Chevelle
mblum is offline   Reply With Quote
Old 07-23-2019, 09:39 PM   #11
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
On my latest ZL1, the suction cup marks from the factory are still visible, in the corner of the windshield glass. I have tried several things, yet they still are there if I look close enough. So I dont look anymore.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 07-24-2019, 07:07 AM   #12
PROMETHEUS
PROMETHEUS's Avatar
So that is what that was! I had one in the upper right corner. I used the Mequiar's scratch remover and it took that off as well.
