![]() Drives: 2019 Camaro ZL1 1LE Join Date: Jul 2019
First Weekend with the ZLE - Impressions & Break In Questions
So this weekend was my first with the ZLE. The car is everything I dreamed it would be and more; I'm obsessed. I've washed it three times since I picked it up on Friday.
I had about a 100 mile drive home from the dealership. During that trip, I did a couple pulls up to 4k from half throttle, 3/4 throttle, and one WOT (3rd - 4th gears). Always shifted right at 4k. This was recommended to me set the rings correctly. Otherwise, she's been babied. Goosed a few times (so hard to resist), but never WOT, and never above 3500-4000. It is my intention to keep this driving style until 1000 miles for break in. I also plan on my first oil change at 500 miles. I'm almost at 300 now. What oil/filter do you guys use? Don't want an argument, is there a consensus on what the best is? Also, when should I consider tranny or other fluid? (6MT) Also, gas. I have a choice between 93 w/ 10 ethanol, or 91 non-ethanol. Any prevailing school of thought on that? What else do I need to do to break it in correctly? This is all street use, no track time for at least a while. I want to make sure I'm really doing everything the right way! ![]() Edit: I found this thread: https://www.camaro6.com/forums/showthread.php?t=552667, I'm assuming that's still accurate? Last edited by Koby; 07-22-2019 at 12:36 PM. Reason: search function actually works |
![]() ![]() ![]() ![]() Drives: 2018 Hyper Blue ZL1 1LE Join Date: Dec 2018
I always use the AC Delco PF64, which is the filter form the factory. The Wix equivalent is good too.
Car is tuned for 93 so use that or it pulls timing, E10 is fine and provides cooling. |
#3 | |
Keep enjoying it. |
