dave@hennessey
Old 07-18-2019, 05:24 PM   #1
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Guessing this is the end..Rod Knock?
Had the car running for less than a month... Not sure what i'm going to do, Just spent so much money getting to this point...Didn't even get a track day...
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 07-18-2019, 05:28 PM   #2
Clarkstar
Clarkstar's Avatar
Drives: 2013 1SS 1LE
I just had the same sound. Pulled it apart and found a spun rod bearing. Picked up a katech 416... had it running in 3 days....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq.
Clarkstar is offline   Reply With Quote
Old 07-18-2019, 05:28 PM   #3
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
What rpm have you been spinning it too? When and how did it start knocking?
Looks like a certain percentage of these motors are not holding up to the big rpm. It's a roll of the dice.
2015 1LE, TSP 225/236 113+3, VMAX Throttle Body, CAI with race scoop, GPI Ported Intake, Land Speed Stage 2 Heads, 1-7/8 headers, NPP exhaust, 25% Fluidampr, LT1-S Monster Clutch, 485 RWHP & 444 TQ
zz430camaro is offline   Reply With Quote
Old 07-18-2019, 05:41 PM   #4
Dylan1214
Dylan1214's Avatar
How much did that run you, if you don't mind?
She's tuned for about 7,300 with my max package..Everything's been going great until now..
Old 07-18-2019, 05:54 PM   #5
zz430camaro
Drives: 2015 1LE
Fu**in sucks man!
Old 07-18-2019, 06:13 PM   #6
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
Where you just driving it normally when it happened? Oil pump maybe?
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 07-18-2019, 06:13 PM   #7
Clarkstar
Clarkstar's Avatar
I called them, they had one in stock, was 6k. Spun mine to 7200.
Old 07-18-2019, 06:20 PM   #8
Dylan1214
Dylan1214's Avatar
I didn't start hearing it until I started her today, I made a small pull last night but didn't hear anything before I cut her off...Maybe she's been knocking for awhile and just started to get loud enough to notice? Idk..
Old 07-18-2019, 06:23 PM   #9
Dylan1214
Dylan1214's Avatar
My oil pressure is actually still normal.. Not sure how that works
Old 07-18-2019, 06:25 PM   #10
sixty9fordkiller
you already have a nice top end. id pull the motor out and tear it down. If the block isnt hurt, id take it to a machine shop just to clean it up real good and get a new rotating assembly and put it back together. It will cost you a lot less than what you paid for that GPI MAX Package and you will have youre car rolling better than ever
https://www.cnc-motorsports.com/cata...3+stroker+kits
Bone Stock
Old 07-18-2019, 06:32 PM   #11
Clarkstar
Clarkstar's Avatar
Mine was also... no difference.
I called all the shops in my area, they were all booked for weeks. Katech had that short block on the shelf... calling my name... so I got out the card and continued on. Ya only live once....
Old 07-18-2019, 06:38 PM   #12
Dylan1214
Dylan1214's Avatar
Very solid advice, definitely going to do this, thanks!
haha understandable, If I had the money right now i'd probably do that same
Old 07-19-2019, 12:51 AM   #13
Dylan1214
Dylan1214's Avatar
Ok so after talking with Ryan at GPI I'm probably gonna go with a new forged 376 rotating assembly and have my local shop clean and install on my stock short block..so new pistons/rods/ and crank and cam bearings..hopefully only be out around 3k...sucks that this happend...but once i have a built bottom end I should be good to go... PS: cheers, been drinking my pain away tonight lol
Old 07-19-2019, 01:15 AM   #14
Dylan1214
Dylan1214's Avatar
Ok guys, I just realized there may be some serious misconceptions here...This problem has absolutely nothing to do with the quality of GPI's products..Shit like this just happens from time to time, no rhyme no reason..I'm not blaming GPI at all.. I personally cannot speak highly enough about their products, and im not trying to be some fan boy, they're well proven within the community..sometimes stock parts fail..so chill out
