![]() Drives: 2022 Wild Cherry SS Join Date: Aug 2012
Memory Seat Issue
The memory seat function on my 17SS works sometimes and not at others. The exit feature works fine but when I get into the car I hit the start button for the seat to move forward and sometimes it does on the first start of the day and then not afterwards. Any ideas?
![]() Drives: 19 Satin Steel 2SS A10 Join Date: Mar 2018
My 17 did this and now my 19 does too. Pain in the ass
![]() ![]() ![]() Drives: 2021 Crush ZL1 1LE Join Date: Oct 2009
Some sort of safety feature? I only use it when the car is off. Wanna be on the pedals before I fire it up. Clutch not fully down and on the brake could be a mess.
2021 Crush ZL1 1LE |
The feature is not used when starting the car..just press the run/start button without depressing the clutch and seat should move forward. Issue is that it does not do so all the time.
PC Technician
Drives: 2016 Hyper Blue 2SS Join Date: May 2012
Hmm, are you using the same keyfob all the time, or do you use both keyfobs?
I use the same fob all the time.
#7 |
![]() Drives: 2018 SS Convertible Join Date: Sep 2018
I have an 18 2 SS is there something that sets it to go once the car is started ....I have to hold the button until I it gets to position ...?
#8 | |
17’&18’s work the same way but the 17’ manual doesn’t tell you that the park brake is required To clarify, auto trans must be in park OR manual trans the park brake needs to be set. Last edited by Sweptwing; 09-17-2019 at 11:31 AM. |
#9 |
Sweptwing you are the man!! You are absolutely correct. The parking brake must be on for the memory seat option to work on entry and the manual does not mention that. I have been fighting with that issue since I bought the car new. Again - thanks for the helpful info!
#10 | |
![]() One other tidbit, you can enter the vehicle set the epb and you’re good to go, the car doesn’t need to set in the garage with epb set. |
#11 |
Yep I found that out also.
#12 | |
![]() Drives: Camaro 2SS Join Date: Jan 2017
2017 2SS stock
#13 |
