Old 07-18-2019, 11:26 AM   #1
Jason18ZL1LE
Drives: 2018 ZL1 1LE
Supercharger Tank recommendations
Hey guys. I currently have the Prospeed 1.5gal fender expansion tank for my ZL1 1LE, however it still deals with slight air issues and requires filling through the valve which is a PITA...
What tanks are you guys using? I prefer something in front of the engine and not on top of the header area and a large fill cap to make bleeding and filling easy since I do road racing and need easy access.
2018 ZL1 1LE - Summit White
529whp Baseline / 760whp 762tq
ARH Ceramic Coated LTH 1 7/8" \ ATI 15% Lower \ RotoFab Big Gulp \ Katech 103mm TB \ Ported Blower \ DSX Fuel System \ Flex Fuel E85 \ Custom Cam \ Dual Springs \ Corsa Exhaust \ Prospeed Heat Exchanger \ Cordes Big3\ C&R Racing Radiator \ LS3 Stat housing \ 160* Thermostat \ NX Lid
Jason18ZL1LE is offline   Reply With Quote
Old 07-18-2019, 11:51 AM   #2
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
I mean the ADM reservoir (basically the edelbrock reservoir with hoses and a mount) is outside of your description since it technically mounts above the headers, but I've had zero issues with it including a very hot track day at 5000 ft elevation. I suspect since when mounted it's essentially the highest point in the circuit, it purges air really effectively (the return draw/suction to the intercooler pump comes off the bottom of the reservoir also).
rlarsen462 is offline   Reply With Quote
Old 07-18-2019, 11:56 AM   #3
Jason18ZL1LE
Are you running stock manifolds or LTH? Are you ceramic coated? Im slightly concerned about heating up the tank since I do mostly desert tracks which can get quite warm. I will be ceramic coating my headers but if I go this route I will be adding a heat shield of some sort to the tank.
Old 07-18-2019, 12:22 PM   #4
Jimabe
Jimabe's Avatar
Drives: 2018 Red ZL1
+1 for ADM rez
Mods: RotoFab Big Gulp, 2" Kooks, Metco 9.1" pulley, Green belt, 103 NW TB, Tune, WeapX Boost Chiller, ADM Coolant reservoir, Jokerz Full Tilt SC Port, Elite E2X Can, Corsa Sport Catback, LED markers, 1LE Tail lights, HO reverse LED's, Red SC Lid, Forgestar 17x11/MickeyT Street R's for Drags
Jimabe is offline   Reply With Quote
Old 07-18-2019, 01:46 PM   #5
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
I'm curious, with the mods you have does your radiator coolant temp rise on track? I'm in the same area with a 100% stock ZLE and track at BW, ACS, WS etc. I'm wondering how a modded ZL1 handles the heat on road courses.
SFV1LE is offline   Reply With Quote
Old 07-18-2019, 01:49 PM   #6
Rlhay2
Rlhay2's Avatar
Drives: 2017 ZL1
I have the Cordes trunk tank.
Rlhay2 is offline   Reply With Quote
Old 07-18-2019, 01:49 PM   #7
PROMETHEUS
PROMETHEUS's Avatar
The more mods, the less likely the stock cooling system is going to handle it. As stock, this car is a beast on the track, along with little to no cooling problems.
Old 07-18-2019, 01:49 PM   #8
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
The Cordes tanks seem like the only two that fit your description, but subscribing if there are others out now.
Mcmillion is offline   Reply With Quote
Old 07-18-2019, 01:53 PM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
On my 2650 page I show how to make the ADM edelbrock setup... for about 60 bucks
I think bite the bullet take out the carpet out and the large foam part in the tire well and run the rule 3700 5 to 7 gallon tanks they work very dam well for 500 or lower.
Or if you have mucho dinereo and care about trunk appearance and want to hide the reservoir a custom tank with the Stewart emp mounted on the rear crash support.
1200.00 buck option maybe more if you ger real fancy with AN lines...
right now Im having a tank made with an exchanger built inside it where i lay ice on the exchanger so i don't deal with flushing or draining the ice out of the system..
Old 07-18-2019, 02:13 PM   #10
rlarsen462
Sell Low, Buy High
Bone stock aside from Soler TB, green filter, and catback
Old 07-18-2019, 02:16 PM   #11
IneedAZ
IneedAZ's Avatar
Why is the ADM so much more expensive than the Edelbrock?
Old 07-18-2019, 03:12 PM   #12
rlarsen462
Sell Low, Buy High
It's mostly markup for putting the kit and bracket together I imagine. I didn't want to deal with putting it all together so I didn't mind paying the premium. I think he's out of stock a lot though.
Old 07-18-2019, 04:59 PM   #13
Alain
Alain's Avatar
That thing is never in stock !!! Been checking in for a while.
Of course, the second I stop checking the website will be the time they get more stock.
2018 ZL1 1LE/Red hot
Old 07-18-2019, 05:19 PM   #14
SilverZl1
SilverZl1's Avatar
Drives: 2018 ZL1
Another vote here for the ADM (Edelbrock) rez. I also have the Prospeed fender tank. Had air pocket issues and solved it by adding the little rez over the drivers side header. I’m running 2” LTH’s with no coating or extra heat shield and have had no heat problems with the ADM rez. Plenty of 100+ degree and crazy humid days here in Texas and I run it hard.
SilverZl1 is offline   Reply With Quote
