Old 07-18-2019, 10:10 AM   #1
john94si
john94si's Avatar
Drives: 17 2ss vert
Panel missing
Well i lowered the top and noticed one of my side covers are missing now. Does warranty replace them? I know they often break here. Its the one that slides down and back when the top moves.
john94si is offline   Reply With Quote
Old 07-18-2019, 01:16 PM   #2
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Probably not missing, just broken and didn't pop up. Hopefully you're still under warranty. Had one of mine fixed last year.
17rsvert is offline   Reply With Quote
Old 07-19-2019, 07:40 AM   #3
Fifty 2SS
Fifty 2SS's Avatar
Drives: 2017 Fifty 2SS w NPP
Had the same happen to me about a month ago. It was covered under warranty though. It has a spring attached to it that had came loose.
Fifty 2SS is offline   Reply With Quote
Old 07-19-2019, 08:46 AM   #4
sklippi2018
Drives: 2021 ZL1 A10
Same happened to me last month. Panel just did not come back up. Still under warranty so they fixed it; tech knew it was a known problem. She's good as new now!
sklippi2018 is offline   Reply With Quote
Old 07-24-2019, 10:07 AM   #5
john94si
john94si's Avatar
Drives: 17 2ss vert
UPDATE.. i went to dealer and asked to order the part.. he called a few days later and said Chevy has a new bulletin to replace the entire assembly including the actuator. So well see if its a permanent fix.
