Old 07-18-2019, 09:00 AM   #1
Katech_Jason
Drives: 2015 Z06
New Gen 5 LT DI injectors - +45% over LT4
Our first 100% XDI manufactured and tested DI-Injectors are designed for the new GM LT series engines. With a 45% increase in flow over stock LT4 injectors, these supply the required fuel flow for high horsepower applications without the need for auxiliary fuel systems. These injectors are based on the original GM LT4 injector, which makes them a perfect drop in solution. Most of the ECU Injector characteristics stay the same.
Every Injector gets tested at 100bar and 200bar on OEM testing equipment at XDI. Every set gets flow matched to within ±0.5% at 100bar and 200bar fuel pressure !!!
Testing on several fully instrumented engines (8x O2, 8x EGT) done by Katech Inc. has shown unequaled results in terms of cylinder distribution, repeatability and stability at pressures up to 3000psi. Tuning changes required are minimal, offsets and current driver parameters stay the same. The injectors are E85 compatible and have so far been tested up to 1308bhp on engine dyno and 1067whp on roller dyno (Ignite E90).
Maximum Fuel Pressure is 220bar / 3200psi.
Straight E85, 1067whp GDI only !!!
no meth, no PFI, no extra ECUs, no wiring, full control, full OBD Diagnostics.
High horsepower GM Gen V V8 and V6 direct injection engines including LT5, LT4, LT1, L86, L83 and LV3
E85 conversions of GM Gen V V8 and V6 engines
2014+ C7 Corvette LT1
2015+ C7 Z06 Corvette LT4
2019 C7 ZR1 Corvette LT5
2016+ Camaro SS LT1
2017+ Camaro ZL1 LT4
2016+ CTS-V LT4
2014+ Silverado and Sierra with 4.3L LV3, 5.3L L83 and 6.2L L86 engines
2015+ Suburban, Tahoe, Yukon and Escalade with 5.3L L83 and 6.2L L86 engines
rated static flow rate: 25.6g/sec at 10MPa
– 67% more flow than production LT1/L86 injectors (15.3g/sec)
– 45% more flow than production LT4 injectors (17.7g/sec)
– E85 compatible
maximum pressure:
200bar / 2900psi (tested rock solid on engine and roller dyno)
240bar / 3500psi (under perfect conditions, no pressure pulsations)
Tuning Support: HPT
https://store.katechengines.com/xdi-...s-45-p819.aspx
Katech_Jason is offline   Reply With Quote
Old 07-18-2019, 09:14 AM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Sweet. But damn those are a pretty penny.
Old 07-18-2019, 05:01 PM   #3
Alain
Alain's Avatar
+++++++1
2018 ZL1 1LE/Red hot
Old 07-18-2019, 05:39 PM   #4
Gunkk
Thank you Al Oppenheiser!
Gunkk's Avatar
4 grand for 1000 hp? That’s a smokin deal!!!
Old 07-18-2019, 07:14 PM   #5
RDBill
902HP 858TQ
RDBill's Avatar
Drives: 2018 ZL1 A10
$4k is just for the injectors capable of making over 1000 HP
RDBill is offline   Reply With Quote
Old 07-18-2019, 08:28 PM   #6
Gunkk
Gunkk's Avatar
Yeah I get it, you still have other things to do, but as a fuel solution it’s 50% more flow than WX injectors for 25% more $$$.
How much does it cost to get a fuel system to 1000 hp with a +30% injector... you still need a secondary supplemental fuel kit, right?
I know these sound like total shill posts, but I have no relationship with Katech and no interest in modding my car, but it seems like a very compelling solution for those who do.
Old 07-18-2019, 11:38 PM   #7
RabbitZL1
Drives: 2018 Camaro ZL1
what high side pump will be able to keep up with these? the belt driven one?
RabbitZL1 is offline   Reply With Quote
Old 07-19-2019, 08:56 AM   #8
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
2016+ Camaro SS LT1
2016+ CTS-V LT4
– E85 compatible
maximum pressure:
Tuning Support: HPT
What kind of FI (turbo, whipple, 2650)
Where were the injector at for instance,,, 6.X milisec? Did they have time to fuel or where they maxed out..
maxed out not meaning loss of rail pressure but as in enough time to complete the burn cycle..
Old 07-19-2019, 08:59 AM   #9
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
I'd be willing to let my FIC 30% go for 2,000 to try these out I have about 600 miles on them now.
After I ported my 2650 I need bigger injectors now..
Old 08-04-2019, 08:33 AM   #10
D3adch1ld
Drives: 2019 Camaro ZL1 1LE
PM if serious
D3adch1ld is offline   Reply With Quote
Old 08-04-2019, 12:32 PM   #11
Markoz28
Drives: 18 ZL1 nightfall grey A10
2k for the +30s! That’s a good deal. I’m sure that plenty of injector to get to 1000hp
Markoz28 is offline   Reply With Quote
Old 08-04-2019, 12:38 PM   #12
EDFHOBBIES
Dyno Show Queen LOL
EDFHOBBIES's Avatar
On e85 alone no.. with meth or race fuel yes..
