![]() Drives: 2019 1LE Join Date: Jul 2019
Does everyone here have a garage???
I have a one car garage and was wondering how many here keep there car outside? I live in South Florida so snow not an issue but the hot sun is. Already ordered my weather teach sun shade. My garage is pretty clean. I have my motorcycle in there, and tool box, and Lawn equipment. Car would fit but it will be very tight. afraid I will scratch the doors getting in and out. Thoughts?
![]() Drives: 2019 SS1LE Garnet Red../Silver CL30 Join Date: Mar 2019
I put mine in a vented garage with a cover over it. The Phoenix sun and heat will wreck the paint and rubber items.
![]() Drives: 2018 Summit White 1SS 1LE Join Date: Aug 2018
I live in Michigan so garage is a must for the winter - even in the summer since I don't drive it every day and would rather keep it nice and safe inside haha!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: '18 1SS 1LE Join Date: Sep 2017
I have split level home built in the early '50's with a small one car garage part of the house so it's climate controlled. Only about a foot and a half clearance on each side so not a whole lot of room.
I call it a car glove. Since it's on what would be like the basement level, in the summer the car is 70°, and in the winter it's about 50°, the heat doesn't make it all the way down there too well. I've been clearing out some excess junk to make as much room as possible. I have a Quickjack stored under the car so have been able to do a couple tire rotations, several oil changes along with two diff and one trans fluid swap. Right now I'm adding some lighting Roadkill style with zip ties to existing objects on the walls/ceiling, still have to get two more 4' LED tubes then it's probably done. Nothing great, but it serves it's purpose.
'18 1SS 1LE Black, PDR
My days off are coming up..going to make room and try it out
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: like an old lady Join Date: Jun 2012
i have a 24x30 detached garage. in the midst of prepping the house for a 31x20 attached garage addition. if i had any seeds i’d build a 30x40 next to my other one, but no..
#7 |
![]() Drives: 2000 GMPPSV SS & 2020 2SS Join Date: Jul 2017
Couldn't imagine life without one.
#8 | |
![]() Drives: SS 1LE Join Date: Oct 2017
#9 |
Drives: Camaro SS 1LE Join Date: Aug 2018
I have a garage, and thank goodness as it will be 112 Fahrenheit today. Be very careful with those super long doors.
#10 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2021 ZL1 1LE Satin Steel Join Date: Jul 2011
Me either and my 3 car isn’t big enough ![]() Ryan B.
Ryan
2021 ZL1 1LE Satin Steel Metallic Build Page: https://www.camaro6.com/forums/showthread.php?t=632481 |
#11 |
![]() Drives: 2018 Camaro SS 1LE Join Date: Oct 2018
I'm going in reverse.
![]() Currently moving from a home with a garage to an older home with some cool "architectural character" that includes a well covered carport, sadly no garage. A little nervous about my car not being fully enclosed, but it should be well protected from elements. On the plus side, it should make working on the car a little more bearable as I will have some breeze available to combat the Texas heat! |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 SS 1LE, 2017 Volt, 2013 Pilot Join Date: May 2014
I have a 3 car, in tandem though, so it can take some planning and moving cars around, yes i get all 3 of my cars in the garage, unlike most of my neighbors, and the one who parks his car in front of my house every freakin day.
anyway, it is over-sized a bit 750 square feet.
#13 |
Retired from Car mfrs....
I also live in South Florida. The sun will kill the car. Do anything you can to keep it out of the sun when not using it. Forget putting a wax on it, you need a sealant and the will hold up the sun better than the standard carnuba wax.
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 1ss camaro Join Date: Feb 2016
nope no garage car is packed outside and is ceramic coated but still wash it about every week or so..in the winter time i use a car cover for the rain
