Old 07-15-2019, 04:25 PM   #1
Tyestick
Tyestick's Avatar
Drives: 19’ Camaro SS 1LE
Question Dealership told me the 1LE alignment settings...
CASTER- left front(7.6 - 0.8) right front(7.6 - 0.8)
CROSS CASTER-left-right (0.0 - 0.8)
CAMBER-left front(-1.0 - 0.8) right front(-1.0 - 0.8) left rear(-1.0 - 0.8) right rear(-1.0 - 0.8)
CROSS CAMBER- left-right(0.0 - 0.8)
TOTAL TOE-left+right (0.2 - 0.2)
STEERING WHEEL ANGLE-0.7 - 3.5
Adviser did not specify at this time if these are OEM or Track alignment specs.
I’m not experienced with alignment settings, so I’m hoping that someone can chime in and share their opinion on this alignment setup.
2019 Camaro SS 1LE
Tyestick is offline   Reply With Quote
Old 07-15-2019, 05:26 PM   #2
kropscamaro16
kropscamaro16's Avatar
Drives: 2016 1ss camaro
sounds like oem to me reference the track manual and it would give the exact track alignment specs
Old 07-15-2019, 05:49 PM   #3
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
Pretty sure that's the standard alignment for the SS with FE3, not the FE4, let alone a track alignment.
Could be wrong though.
'18 1SS 1LE Black, PDR
Old 07-15-2019, 10:41 PM   #4
BigShow1960
BigShow
BigShow1960's Avatar
Drives: 2017 1 Camaro + Chevy Avalanche
Look at the 1LE supplement. After the last time the dealer misaligned my car I pulled out the high performance supplement, they photo copied, and I came back the next day to pick it up. The first time they didn't torque one of the camber bolts. Never taking my car back to that dealership.
BigShow1960 is offline   Reply With Quote
Old 07-16-2019, 01:31 AM   #5
Uncle Sam
Drives: 2017 Camaro 1LE Hyper Blue
Check the supplement. Here is what I got:
Uncle Sam is offline   Reply With Quote
Old 07-29-2019, 06:28 PM   #6
FH212
FH212's Avatar
Drives: 2015 Camaro Z/28
So are these the specs for aligning for the street and NOT the track alignment? Can anyone confirm? I would prefer to do the street alignment on mine now.
2015 Camaro Z/28 - Red Hot
1978 Trans Am Y88 Special Edition 400/4 speed
2001 Mecham Trans Am #3 - 7.0L LS1
FH212 is offline   Reply With Quote
Old 07-29-2019, 07:20 PM   #7
TRZ06
TRZ06's Avatar
Drives: 22' Porsche PDK GT4
I am not sure if they are within spec, but just looking at the camber numbers, that is definitely street settings.
The track settings are -2.5 front
Current:
Previous:
09' C6 Z06
08' E90 M3
06' 335i (KW V2 Coilovers)
03' C5 Z06
Old 07-29-2019, 11:37 PM   #8
Tyestick
Tyestick's Avatar
The alignment specs in my original post are OEM specs, per my dealership advisor, and NOT track alignment specs.
2019 Camaro SS 1LE
Old 07-30-2019, 08:49 AM   #9
FH212
FH212's Avatar
Perfect. Thank you.
