![]() Drives: Chevrolet Camaro ZL1 Join Date: Jul 2019
Hard Launch Clutch Pedal Didn't Fully Engage
At the last Autocross event I participated in, the starting line was fairly straight meaning that you could really launch the car hard (M6).
On several of my launches (using launch control set to automatic) the clutch pedal wouldn't fully come off the floor. It's like the car's computer was leaving the last couple inches disengaged to protect the drive train. Is this a thing? The RPM's would continue to rev but the clutch wouldn't fully engage so I had a horrible start and when I came back to the pit's, there was an obvious clutch smell. It only fully engaged when I lifted off the throttle pedal a little bit. I thought these drivetrains were supposed to be pretty strong? |
1. Glazed your clutch surface launching to "smoothly"
2. Check your brake fluid reservoir, full? Just throwing crap at the wall here...
2018 Camaro SS 1LE - 2011 370z - 2004 VW R32 - 2000 Civic Si Mods: Rotofab, Nick Williams 103mm TB, MSD IM, Kooks 1 7/8 Results: 470 hp / 447 tq |
Thank you Al Oppenheiser!
more crap
3. sticky throw out bearing.
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
I agree. There's no electronic control for the clutch, whatever the issue is will be a mechanical failure.
2017 SS 1LE.
Brake reservoir is full. Recently did a DOT 4 change.
Likely glazed clutch. Really hard to modulate the launch. The sweet spot must be smaller than my ex-wifes heart. Releasing the clutch any quicker and the engine usually cuts out. I think that must be what the notorious "engine bog" is? |
Were you feathering while using launch control? Launch control on these cars is designed to press the clutch all the way, put in first, go to WOT, then dump the clutch. Shouldn't ever kill the engine if everything is OK with the car, and also shouldn't feather the clutch as this will interfere with the launch control algorithm and can damage stuff (including the clutch).
If not, maybe there's air in the system from the swap to dot4?
2017 SS 1LE.
