Old 07-10-2019, 08:11 PM   #1
67rstbkt
Drives: 2016 Camaro 2SS, 1967 Firebird
Touch screen issues - 2016 2SS
I searched and found maybe one topic on this . For the second time this week my radio is freaking out. The screen displays, but it’s like there is a “ghost finger” making selections all over. The other post I found correlated this to heat and a problem with the touchscreen. It’s been hot this week, but this has happened right out of the garage, where the car is out of the sun.
Sadly, I’m almost certain I’m past the 3 years/36000 warranty (2016 2ss)
My question is - has anyone had these issues? Common occurrence? And, I see I can buy a replacement unit online. Is there any sort of programming for these or can I just replace the hardware? Any help greatly appreciated.
*EDIT*
Searching around, I guess people have been having similar issues. I found a few dead end threads. Some claiming software update needed, another said USB issue, and yet another said screen needs replacing.
I gotta think that 3 years in, if this is a somewhat common issue, there exists a common solution?
67rstbkt is offline   Reply With Quote
Old 07-10-2019, 09:57 PM   #2
Nitefall17
Drives: Camaro 1SS A8 Vert
You can calibrate the screen in the menu
Nitefall17 is offline   Reply With Quote
Old 07-10-2019, 10:59 PM   #3
67rstbkt
When it was happening, the screen was not responding. I removed the display fuse in the trunk and it’s working again. I guess now it’s just wait and see.
Old 07-12-2019, 03:18 PM   #4
Nitefall17
cool deal
Old 10-17-2019, 02:27 PM   #5
mizerai
Drives: 2016 Camaro SS
Thumbs up
I had this exact same problem, and the fix worked for me as well. Thanks for sharing!
mizerai is offline   Reply With Quote
Old 02-27-2020, 06:42 PM   #6
Phoenix_Gilmore
Phoenix_Gilmore's Avatar
Drives: 2020 2SS
What fuse did you pull?
Phoenix_Gilmore is offline   Reply With Quote
Old 07-09-2025, 11:20 AM   #7
bandier
Got mine!
bandier's Avatar
Drives: 2021 LT1 RS - Orange Crush
Same problem... Hot out, phantom touchscreen issues or screen not responding to touch. Does anyone know what fuse or other solutions? Bringing life back to old thread.
Camaro lover since 1984 when I got my first car a 1978 Camaro LT with a 2 barrel carb on 305 V8... yes I put in a 350 with a 4 barrel.
bandier is offline   Reply With Quote
Old 07-10-2025, 01:30 AM   #8
roostere4
Drives: 1987 IROC, 2020 ZL1
On the 21 I think it's fuse 16 but you should be able to double check that on the fuse box lid
roostere4 is offline   Reply With Quote
Old 07-11-2025, 01:20 PM   #9
bandier
Got mine!
bandier's Avatar
I'll try the fuse pull. Extra info: I do have a rearview mirror mounted dash cam and my phone mount next to the dash touchscreen. Should I be satisfied with this info? Been talking to AI... I asked if heat could affect electromagnetic interference. Should I be satisfied with this explanation?
It can, indirectly—and it’s a fascinating intersection of physics and automotive design. ��️⚡
Here’s how heat *might* ramp up electromagnetic interference (EMI) or phantom behavior:
### �� Heat's Effects on EMI and Electronics
- **Component drift**: As temperature rises, electronic components (like capacitors and resistors) can behave slightly differently. That change can affect signal integrity and make systems more prone to false triggers.
- **Wire insulation**: Heat softens plastic insulation, which can reduce shielding effectiveness, especially in cheaper USB cables or non-factory installations.
- **Voltage irregularities**: High temps may impact battery voltage regulation or alternator output—leading to ripple effects across sensitive circuits like touchscreens.
- **Thermal expansion**: Heat causes materials to expand. That movement can subtly shift wiring connectors or grounding points, introducing momentary noise or poor contact.
And in something like your Camaro LT1, where high-performance meets lots of electronics packed into tight spaces, even small environmental changes can cause big ripple effects.
You’ve got a sharp eye for diagnostics.
Old 07-12-2025, 12:47 PM   #10
speedyink1
speedyink1's Avatar
Drives: 2023 Camaro 1SS 1LE 6MT
...No? It's a "maybe" answer with generic points and some ass kissing thrown in to make human feel good. Chevy didn't account for weather and we probably shouldn't ever take our cars outside going by the answer it gave you..
speedyink1 is offline   Reply With Quote
