Old 07-09-2019, 11:44 PM   #1
aeagleaaron
aeagleaaron's Avatar
Drives: 2017 Camaro ZL1
2017 burning oil
I have about 18,000 miles on this car. I bought it brand new, broke it in like I was supposed to (by the manual). I noticed it burning a lot of oil. Like it had 72% oil life left and no oil on the dip stick. I took it to the dealership and they are having me do a oil consumption test. Basically checking the dip stick on every fueling. The tech told me that most likely I am looking at a new engine. Anyone else have this issue?
aeagleaaron is offline   Reply With Quote
Old 07-10-2019, 07:24 AM   #2
jvandy50
Drives: 18 ZL1-1LE, 10 JKU
we need to know how many miles you drove since last time it was checked/full brother.
mine burns a little bit, but coming from a GT350, this is nothing lol.
jvandy50 is offline   Reply With Quote
Old 07-10-2019, 07:53 AM   #3
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
I hope my 2017 doesn’t start using oil! This has me wondering now.
Old 07-10-2019, 08:01 AM   #4
unavailablezl1
unavailablezl1's Avatar
Drives: 2019 Silverado Z71 6.2L A10
I did the same thing. Broke it in, mostly careful, and I like to drive it kinda hard. 60% of the shifts are to 5k rpm with some almost redlines thrown in. Hey, it's a ZL1 sports car. Mine burned close to a quart+ in 1200 miles. So I did the same unit test as on my 500 miles per qt GT350. Got on the freeway, played nice, did 65-70, no high revs, almost no city driving. I drove 1500 miles and it burned nothing. So it might be just how you drive it.....like a ZL1 Sports Car.
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's.
Past Rides
2017 M6 Camaro ZL1 Hyper Blue
2016 M6 GT350 White with blue strips
2014 M6 Mustang GT Premium Track Pack Ruby Red
2012 M6 M3 Melbourne Red Metallic
unavailablezl1 is offline   Reply With Quote
Old 07-10-2019, 09:36 AM   #5
HDRDTD
How many miles on this last oil change that now reports 72% life left?
Old 07-10-2019, 10:38 AM   #6
Canadian ZL1
Canadian ZL1's Avatar
Drives: 2017 ZL1, 1995 Trans Am
The dealership will tell you that it's normal to have to add up to 1 litre of oil if your dipstick is calling for it. While I don't agree with this statement it is what it is. I would get a compression test done by the dealership first. Get a fresh oil change and monitor your dipstick every 500 km's (310 miles). This will be the only way to determine how much oil it is burning.
_____________________
'17 ZL1 HBM|A10|NAV|PDR|CFW Hood|Sunroof
Canadian ZL1 is offline   Reply With Quote
Old 07-10-2019, 10:49 AM   #7
gblaue
gblaue's Avatar
Drives: 2017 Bright Yellow ZL1 6spd
My 17 uses about 1 qt every 1500 miles.
2017 ZL1 Bright Yellow w/ black center stripe, 6 speed, CF gas door, PDR, Navi
gblaue is offline   Reply With Quote
Old 07-10-2019, 11:15 AM   #8
Elite Engineering
Elite Engineering's Avatar
Drives: 2010 Camaro
Breaking it in as the owners manual states will give you about a 50/50 chance rings will seat properly. You only have a 400-500 mile window for the rings to abrade into the shape of the cylinders before a hard glaze sets in and covers the crosshatch before that window has past. The actual GM instructions for techs and other mechanics is as follows, but they would never expose themselves to the liability of having the average consumer follow these as most can understand if someone crashed doing full throttle when GM told them to a huge lawsuit.
The instructions given to new vehicle owners you must understand are a combination of general guidance and legal liability protection. Very little is accurate on how to best care for your engine....Ford and every other automaker is the same.
If your rings did not seat, GM is replacing the engines and NOT rebuilding them. They go back to GM and they re manufacture them there.
Good Luck!!!
Elite Engineering is offline   Reply With Quote
Old 07-10-2019, 11:52 AM   #9
rlarsen462
Sell Low, Buy High
Drives: 2022 ZLE, 2023 ZLE (Inbound)
Data point:
2019 ZLE, beaten like a red headed step child from day one. WOT, redline, etc. Tracked at 1500 miles on a hot day, 8 x 30 minutes sessions flat out.
Have literally not burned a drop of oil near as I can tell. Car makes great power.
rlarsen462 is offline   Reply With Quote
Old 07-10-2019, 11:57 AM   #10
SteveV
SteveV's Avatar
Drives: 2018 ZL1 Camaro 6M Red Hot
I typically go 6000 miles between oil changes. My 2018 usually needs another quart around the 5000 mile mark.
But, my 5th gen Camaro did this and so did my 2014 Silverado with the 5.3... So, this all seems kind of normal for a Chevy V8.
But, as others have noted: you didn't really tell us how many miles since it last showed full on the dipstick...
People are a lot like slinky's: not very helpful most of the time, but they bring a smile to your face when pushed down the stairs...
SteveV is offline   Reply With Quote
Old 07-10-2019, 12:10 PM   #11
Mark R
Drives: 2018 ZL-1
Originally Posted by rlarsen462 View Post
Data point:
I am in agreement with you. An engine broken in hard seats the rings much better than one that is babied for 1000 miles. You can give an engine WOT without revving it too high, just like that Chevy break in bulletin above. I started hammering on my car after just a short time, with full throttle runs after 100 miles or so.
Old 07-10-2019, 01:44 PM   #12
Larrio Andretti
Drives: Really Fast
Good Luck!!!
Exactly.... I build motors and after 20 mi or so they go right to the track. Never had an issue with rings not seating. Plenty of issues with new engines driven lightly with ring sealing issues. Break it in like you stole it!
THIS SPACE FOR RENT
Larrio Andretti is offline   Reply With Quote
Old 07-10-2019, 02:55 PM   #13
SFV1LE
Drives: 2018 Hyper Blue ZL1 1LE
For ZL1s, it's important to build some boost (not lots of full boost) during break-in for the rings to seat properly. The rings in the LT4 are subject to much high cylinder pressures than NA motors like the LT1, and therefore must seat differently under boost in order to function properly and contain the combustion gasses under those higher cylinder pressures.
In other words, don't stay out of boost during the break-in period but as always make sure the oil is a full operating temp before you give it significant throttle and boost--at least 200 F in my opinion.
SFV1LE is offline   Reply With Quote
Old 07-10-2019, 03:07 PM   #14
Canadian ZL1
I hate to agree with you but I was one of the dummies who babied and follow the break in procedure as per the manual. Had I not been so self conscious I’m sure my motor would of properly seated. In other words I should of been a little harder on the car during break in despite what the manual said.
I have to add 1 litre of oil every 2500km’s . It’s consistent in terms of every oil change I do after 2500 Km’s driven the dip stick is just the bottom of the crosshatch. The only good news is it passed the compression test, no white or black smoke from exhaust and no oil leaking from underneath. Since I only have to add 1 litre of oil during every oil change I can live with that. Also as a back up I have my full warranty in case it needs to be used. Have 20,000kms on the car and she is strong as ever.
