Old 07-08-2019, 04:09 PM   #1
UserNameNotFound
UserNameNotFound's Avatar
Drives: 17' Camaro ZL1
Talking First tracknight with my ZL-1
Hey folks! I just had the chance to put my ZL-1 on the track (PIR - Portland) last Friday and it was great.
No question it is the best track car I ever had.
Overall the car did great, tires, brakes, no heating issues, all good and better than expected.
Best lap was 1:29.9 and I think it can be improved a lot if I get no traffic in and a clean lap.
I believe the brake pads and even the brake disks might be due soon.
I was hoping to get some recommendations on what would be the best options for the brakes and also tires. What has been proven to work on the track and also do well on the streets (car is my DD)?
Here are some pics:
https://www.camaro6.com/forums/album.php?albumid=21480
Videos:
https://photos.app.goo.gl/nexAAo85ehnubMoD8
https://youtu.be/fg6ldqponfE
https://youtu.be/keqEmJc_ZtI
The last one has the best lap, right after passing the GT3. Unfortunately, the audio is awful as the window was open and the PDR cam picks up the noisy pretty hard. Anything that can be done (other than closing the window) to improve that?
Thanks all for any inputs/tips.
UserNameNotFound is offline   Reply With Quote
Old 07-08-2019, 04:15 PM   #2
Lafourche1
Drives: 2019 CLA 450 Mercedes
If you are tracking the car, the OEM tires and brakes (pads and rotors) are very good. You will be hard pressed to find better for both DD and track use. Dusting with the stock pads is the price you pay for the lack of squeal (true race pads) or no dust and far less stopping power for pads that don't dust.
The tires are very good, too. They work well when you get some heat in them. They are not the longest lasting, but last far longer than the R version or Cup 2s.
2019 Lunar Blue Metallic Mercedes CLS 450
2021 C43 AMG Mercedes Coupe Metallic Cardinal Red
2014 Lincoln MKT EcoBoost (The Bus)
Lafourche1 is offline   Reply With Quote
Old 07-08-2019, 04:17 PM   #3
Heartbreaker
Heartbreaker's Avatar
Drives: 2020 Camaro ZL-1 1LE
Here are some pics:
Videos:
Castrol SRF brake fluid and a track alignment are great for the track. The OEM brakes are impressive. Did you change out the brake fluid?
Heartbreaker is offline   Reply With Quote
Old 07-08-2019, 04:38 PM   #4
UserNameNotFound
I don't care much about the dusting. Squealing is much more annoying. I would do the trade if I knew the race pads would improve the braking significantly, though.
I have not changed it yet. I am hoping to do it as I change the pads. Thanks for the tip on which fluid to use. :-)
Is the track alignment what is listed in the high performance manual?
Doesn't it come like that from factory?
Old 07-08-2019, 05:41 PM   #5
PROMETHEUS
PROMETHEUS's Avatar
Got to change that brake fluid!
Old 07-08-2019, 07:01 PM   #6
rmh3
Semper Fi!
rmh3's Avatar
Drives: 2018 ZL1
Nice!
What track in Portland?
I want to hit it up and run against my brothers 911 4S.
rmh3 is offline   Reply With Quote
Old 07-09-2019, 08:57 PM   #7
DangerZL1
Drives: 2023 Black ZL1 Auto
The car really needs to be aligned before delivery. It’s definitely not set to the trac specs.
Old 07-09-2019, 09:51 PM   #8
esm
esm's Avatar
Drives: 2019 ZL1
Race pads and SRF fluid will make a big difference. I don't have track experience with the ZL1 yet but I do with a 2015 Viper. On high speed tracks you need pads and fluid.
Call Ken @ https://www.knsbrakes.com/c/home
Very knowledgeable and helpful. I bought Hawk DTC - 70 pads front and rear from Ken to go along with an extra set of track only stock rotors.
2019 Black ZL1 - A10
esm is offline   Reply With Quote
Old 07-09-2019, 11:05 PM   #9
Gonasurvive
Gonasurvive's Avatar
Drives: 17 ZL1 MBM M6
Thanks for sharing, bet you had a blast on PIR! By the way we have twin cars in Portland, mine is Mosaic Black though. So if someone said they saw you, it was probably me lol. I know it already happened to me a couple of times. When did you get yours, got mine Feb 17?
Gonasurvive is offline   Reply With Quote
Old 07-10-2019, 07:10 AM   #10
SWZL11LE
SWZL11LE's Avatar
Drives: '19 ZL1 1LE
If you are looking for a streetable trackday tire, the tires on the ZLE are pretty impressive, which are the GoodYear Supercar F1 3R. Also the Yokohama Advan A052 might be worth looking into, but the Yokohama's have very few sizes in 19 and 20 inch diameters.
SWZL11LE is offline   Reply With Quote
Old 07-10-2019, 08:05 AM   #11
Apexslayer
Drives: Zl1 1le
I've done several track days over the past two years. If this is a road and track car, stick with the OEM pads! They cannot be beat for price and performance. Also - make sure you are using Motul or SRF brake fluid!
Apexslayer is offline   Reply With Quote
Old 07-10-2019, 08:12 AM   #12
mt.nichols
Drives: '19 ZL1 1LE
I will echo advice of previous posts and say stick with OEM pads. You want to try and balance your pad's braking torque and the tire's available grip. IMO, even with the Goodyear SuperCar 3Rs on my 1LE, there was plenty of braking torque with the OEM pads.
Do change the brake fluid though. I am running Castrol SRF and it has been great so far.
mt.nichols is offline   Reply With Quote
Old 07-10-2019, 09:59 AM   #13
viurniel
@viurniel
viurniel's Avatar
Drives: 19 ZLE A10, 15 2SS, 90 300ZXTT
OEM pads for most drivers is the way to go. Options are G-loc and Hawk for more bite, but these options are not great for daily driving.
However, the brake fluid should be changed to DOT4.
So many options for brake fluis, so here is a link to Brake Fluid Data
Most folks here prefer Castrol SRF, and Motul 600 or 660.
viurniel is offline   Reply With Quote
Old 07-11-2019, 08:51 AM   #14
Snakebt6
Drives: Rally Green 2020 ZL1 1LE A10
I think you can put a small piece of foam over the speaker for the PDR and that might help. Scotch tape it maybe so its easily removable?
I was considering that myself actually as over 60 or so its pretty annoying to listen too on play back.
On the advice of one of the guys here stock tires and pads etc..and I only changed the brake fluid to Castrol SRF. Lets face it I personally will never outdrive the car lol
Snakebt6 is offline   Reply With Quote
