Old 07-08-2019, 03:23 PM   #1
Ricard350
Drives: 2019 ZL1 A10 in White Summit
I hate myself right now....
Just got out of the car an hours ago and stumple a bit when got up and my right foot landed close to the side skirt and my boot eyelid sttuck my sideskirt....
I think the paint code number is W40A848 for satin black .
I will need to be ordered, in the mean time ill use my Kia Cadenza black touch up paint pen that has metallic flakes in it, it will still be better than exposed grey plastic...
Im so pissed at myself....
Ricard350 is offline   Reply With Quote
Old 07-08-2019, 03:28 PM   #2
Can'tHave2MuchHP
Can'tHave2MuchHP's Avatar
Drives: Fast
Stuff happens. I wouldn't recommend putting anything on it until you have the real deal.
The side skirts are Mosaic Black, paint code GB8 from GM or WA-384A for touch up paint.
Old 07-08-2019, 03:45 PM   #3
Ricard350
Called my dealer and they have gb8 wa-384a touch pen but under the name black meet kettle instead of mosaic black
Same thing?
Old 07-08-2019, 03:51 PM   #4
Ricard350
According to this it seems like accessories would be another paint....
Side skirt would be an accessory right?
Im a bit confused...
Old 07-08-2019, 04:05 PM   #5
staples87
Drives: 2017 Camaro ZL1
It happens man.. and it's not surprising either. The paint and clear coat are so thin to begin with.
'17 Camaro ZL1 M6
staples87 is offline   Reply With Quote
Old 07-08-2019, 04:25 PM   #6
Can'tHave2MuchHP
Drives: Fast
That's interesting but I don't think it's accurate for the side skirts. They're definitely not Satin or Semi-Gloss by any definition. The 1LE side skirts are a satin/flat black.
Black meet kettle metallic was the name at some point for Mosaic Black. The paint code is WA384A.
Your side skirts in your post look very gray and not the deep black of Mosaic but that could be due to lighting or them being dirty. Can you confirm?
Old 07-08-2019, 04:36 PM   #7
These colors have several fancy marketing names, don't get hung up on Black Meet Kettle vs Mosaic Black. My color is Garnet Red Tintcoat aka Red Obsession aka Caught Red Handed, for example. What matters is the code, which is GB8 or its equivalent WA384A in your case.
If you see metallic flakes in the paint under illumination, it definitely is GB8, if not, it could be the semi-gloss black wonder you found in that table or a proper gloss black. I can't tell from the pic, because your side skirt is dirty (sorry).
Looking at the chip, there is a good chunk of material missing, so if you just touch it up with paint, you'll still have the visible ridge, you may want to add some filler before painting or have a body shop fix this properly.
Old 07-08-2019, 04:56 PM   #8
Ricard350
Just making it black will be 1000x better that gray bare plastic, ill apply several coat to fill it then wetsand with 3000grit with tape around it.
Old 07-08-2019, 05:05 PM   #9
headgamez
Drives: 2018 Camaro ZL1
Caught red handed, lol!!!!
headgamez is offline   Reply With Quote
Old 07-08-2019, 05:14 PM   #10
Good luck, man, and don't beat yourself up, such s**t happens to all of us
Old 07-08-2019, 05:25 PM   #11
Stephen12ZL1
Stephen12ZL1's Avatar
Drives: '21 ZLE A10
it happens...it is a Camaro, and it will happen again! Good luck with the fix
Old 07-08-2019, 06:35 PM   #12
Ricard350
My friend that did a full IGL quartz+ (ceramic coat) on my car also does paint correction, he will be able to blend it pretty good, he will take care of it after his vacation.
In the mean time he told me just cover it up with 1 or 2 quick tap with the brush.
Thats what i just did.
Looks better than grey bare plastic...
Old 07-08-2019, 08:29 PM   #13
Alain
Alain's Avatar
Dude, I had a paint chip right above the passenger side rear wheel well. It was down to the bare metal !!! I have no idea how the hell that happened !!!
I lost sleep for 2 weeks when I first discovered it. I finally accepted that the car is going to get some blemishes here and there. I touched it up, got it ceramic coated and put clear bra over it.
Do your best to move on. It’s a car and it’s going to have paint issues at some point
2018 ZL1 1LE/Red hot
Old 07-08-2019, 08:39 PM   #14
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Can't tell you how many times I have used a sharpie on these kinds of things.
1hprush is offline   Reply With Quote
