![]() Drives: 2018 2SS Join Date: Sep 2018
GPI Drop In Rods And Pistons
Has anyone installed the GPI drop in Rods and pistons kit?
![]() ![]() ![]() ![]() ![]() ![]() Drives: Hyper Blue 2016 2SS 6M Join Date: Sep 2017
I've been running the gpi piston/rod combo for a couple of months now and have been very pleased so far. I was a little concerned that the recommended .005 piston/cylinder clearance would cause false knock retard when cold or lead to greater than stock oil consumption but these concerns have proven to be completely unfounded. I am completely satisfied and recommend these parts to anyone pushing over 650 or so rwhp
Baby Blue
2016 loaded 2SS
Drives: Maverick X3 Turbo R Join Date: Feb 2015
yup if you check my build thread you can see the install pics
these pistons/rods are taking 1000+ on a daily basis too.
![]() Drives: 2018 2SS HBM Vert Join Date: Dec 2014
I am running them as well and no issues. Great product and great people to deal with.
Whipple 3.5 upper, 9.1 lower, BTR 2, TSP L/T's, Rotofab, GPI Rods/Pistons, LT4 fueling, DSX Aux, ECM/TCM tune ...
![]() ![]() Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
I blew out a ring land in #7 after adding a Whipple. Happy to see no damage to the cylinder wall. I decided with GPI, good people and product. Slightly honed out the cylinders and plug and play. Did not need to balance. I’d suggest them to any LT1 set up.
#7 |
![]() Drives: 2016 Camaro SS Join Date: Jul 2016
I installed them for 2 Camaros, they are working very well. It is "Drop-in". no need to be balanced again
GPI , they have nice guys. recommended. |
#8 |
Have any of you guys done the work yourselves other than L78toLT1?
2018 Camaro, Whipple Charged, RotoFab Big Gulp, Katech 103mm, LT4 Fueling w/ JMS BAP, GPI Drop in Rods and Pistons, Custom Cam, Ported Heads, Kooks LTHs w/ Green Cats and Mid Pipes, Corsa Extreme Mufflers, DSS Driveshaft & CV Shafts, Might Mouse Catch Can, Circle D T.C. #Team GPI
#9 | |
Sounds like the GPI setup is the right thing to do. I heard that Aaron is one of the better professionals when it comes to securing the reliability of a boosted LT1 Gen.5 motor. |
#10 |
Did you actually weigh the stockers side-by-side to the GPI combo to verify that there is no variance (or at least no significant enough one to call for a balancing of the RA)?
#11 |
I balanced mine but the amount of metal added/removed was so minor it would have been fine to have just dropped them in.
Baby Blue
#12 |
It wasn’t much. Whipple at about 6-7 boost with 3.5 upper. From what I’ve read some LT1s are fine and others not so much. Luck of the draw. Feel so much better now that I put them in and added a BTR stage 2 and turned up the boost.
