Old 07-03-2019, 07:35 PM   #1
Kerry
Drives: 2019 2SS Camaro
Tall vs short tires
So if anyone has any experience please help. Going from a 28 inch tire down to a 27 make enough acceleration difference to feel on the butt dyno?? Camaro ss
Kerry is offline   Reply With Quote
Old 07-03-2019, 08:35 PM   #2
6spdhyperblue
Drives: 2SS 1LE
26.1” yes it spins up faster
Old 07-07-2019, 02:26 PM   #3
RuthleSSchevy
RuthleSSchevy's Avatar
Drives: 2016Camaro+1968Chevelle+1954BelAir
Depends on the tire but you will deffinetly experience wheel spin and will have to adjust your heavy foot accordingly. Ive run 26 -30" tires on the ss and prefer the 29 with my setup. NA id likely go smaller
"Lead me, follow me, or get out of my way." GGSP
RuthleSSchevy is offline   Reply With Quote
Old 07-07-2019, 03:50 PM   #4
KLG
KLG's Avatar
Drives: 2016 2SS Convertible
About the same impact as keeping the 28" tires and changing the rear end gearing from 3.73 to 3.87 (if such a rear end ratio were available).
--KLG--
2016 2SS Convertible; SIM; Black & Ceramic White interior; M6; NPP; DD LED side marker lamps & back-up lamps; LED trunk lamps, license plate lamps & front T/S lamps; 3rd brake light pulser; Skip-shift eliminator; Borla s-type non-npp axle backs; Weather-Tech floor mats, trunk mat, rear license plate frame/cover; GM fuel door; ZL1addons rock guards; Removed fender badges, front & rear SS badges; JLT CAI, tune, oil separator; RP Synchromax in transmission; RP MaxGear in rear differential; GM Lowering Suspension Upgrade; Dimple oil filter magnets & magnetic oil drain plug; 3M Ceramic window tint.
KLG is offline   Reply With Quote
Old 07-09-2019, 10:31 AM   #5
Kerry
So a little more info. I have the toyo r888rs in a 315/30/20 its like 27.5 but is just a little taller than that in realialty taller than the stock run flat. Got a best of 3.9 0-60 put on the firehawk 500 in 285/35/20 for every day. this tire is very narrow but I got a best of 4.1 0-60 I love these firehawks. smooth quite and supriseing traction.
So heres my delima the 285 is narrow and tall at about 28.2 real world only 8 in tread width,thinking of going to the 295/30/20. Should gain an inch in tread width but only 27 in tall. What to do?
So I really like the look of the 285 but would the 27in look good or tiny?
Would the 295 incres the butt dyno feel being about 1 in shorter? I would give a little on the look for a better feel.
Would I loose 0-60 with the shorter but wider tire?
Any input would be very much appericated. Car is basic stage 2 procharged ss as the only mod.
Speedometer was corrected for all runs. With the procharger its hard to get good 60 times because so much power spins more.
