Old 07-03-2019, 05:55 PM   #1
thrashergrant
thrashergrant's Avatar
Drives: 2018 Camaro SS 1LE
Ordered Diff Oil - GL-5? What is this?
I ordered some oil to do my 2nd diff fluid change. When I made the purchase I was sure to double check the part numbers and oil requirements.
I received the oil today. It is the correct part number (88862624) but the label has this weird designation next to the oil weight: GL-5
What is this? This oil is the same part number as the factory oil so I assume its the same stuff, but my previous bottles didn't have this.
Am i good to go using this?
thrashergrant is offline   Reply With Quote
Old 07-03-2019, 07:04 PM   #2
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
GL5 is a specification calling for EP (Extreme Pressure) applications which you would typically find in Limited Slip type environments as in our rear diffs.
There is plenty of material online that explains differences between the various GL specs. (mainly 3, 4 and 5) Also many Youtube videos.
Just do a search, read & watch and you shall understand.
Old 07-03-2019, 07:31 PM   #3
thrashergrant
Cool, thanks for the summary. I hadn't seen this specification on the label before and just wanted to make sure it is okay to use.
Old 07-03-2019, 09:50 PM   #4
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
My fluid, same part number, doesn't have the GL5 on the label, picked this fluid up earlier this year.
'18 1SS 1LE Black, PDR
Old 07-03-2019, 10:07 PM   #5
thrashergrant
I'm noticing a few other differences as well:
The volume on the fluid I'm used to seeing is "Contents: 32oz. (.946 L)"
The volume on the fluid I just received is "Net Contents: 1 QT (946 mL)"
Could this possibly be from a larger, bulk quantity? That's all I can think of to explain the discrepancy...or it's a rip off?
Has anyone else seen this before?
Old 07-04-2019, 07:12 PM   #6
Eldi Z
If you got it from a reputable dealer then it should be fine. Probably just an updated bottle.
Old 07-04-2019, 07:56 PM   #7
enzia35
Drives: '16 Garnet Red 1SS
Yep, this. Instead of having to look at the back to see what rating it is, it's on the front now!
I had a shop change out the fluids, and I used the OEM stuff like that for the diff. It seems to run just fine.
'16 Camaro 1SS
'18 Miata GT
Old 07-05-2019, 09:44 PM   #8
pkincy
pkincy's Avatar
Drives: 2016 Corvette Z06, 2018 ATS-V
Don't have a Camaro or a Camaro Owners Manual but that is the part number recommended for the C7 Z06 diffs. It is, or at least was when I flushed mine, at a pretty good price from Amazon.
Perry
16 SharkGrey A8 Corvette Z06
18 Cadillac A8 ATS-V
pkincy is offline   Reply With Quote
Old 07-06-2019, 08:26 AM   #9
Eldi Z
When I change my fluid, this is what I am going to use.
https://www.lgmotorsports.com/access...-ls-75w90.html
https://www.summitracing.com/int/par...2686/overview/
Especially since reputable shops, like LG Motorsports, who specialize in drive-train and suspensions recommend it, then I trust it to be top notch quality and equal and probably better than the OE/AC-Delco stuff.
Old 09-27-2022, 09:02 AM   #10
CZRENE6ADE
Drives: Chevrolet Camaro LT1
Did you use it only for differential or also for the transmission?it was good?
CZRENE6ADE is offline   Reply With Quote
Old 09-28-2022, 02:40 PM   #11
Boost Creep
Drives: '18 1SS 1LE
Diff fluid is gear oil, trans fluid is ATF.
Two completely different oils.
Old 10-03-2022, 02:05 PM   #12
Eldi Z
Diff only.
Tranny for modern Tremec TR60xx applications is ATF / Similar Viscos to ATF
