Old 06-28-2019, 10:33 PM   #1
BayStreet510
Drives: Yellow 2016 Convertible SS
Two questions on installing an amp ‘16 1SS
Its the non BOSE system.
Im installing a powered sub. I’ll use the sub thump harness. I’ve installed amps before.
My only questions are:
Where do I tap for the amp remote turn on wire?
Will I need any other harness or trickery to eliminate any noise/issues that these systems have with aftermarket subs?
Thanks!
BayStreet510 is offline   Reply With Quote
Old 07-02-2019, 11:21 PM   #2
StPeteHyper2.0
StPeteHyper2.0's Avatar
Drives: '16 Hyper Blue 2.0
Use a Audiocontrol LC2i.. easy install with the sub thump harness. Use the rear L/R wires to eliminate amplied door chimes. You can also unplug the harness to the left of where you plug the sub thump harness into the amp (closest to the back of car) to delete unnecessary noises such as exhaust imitations.
StPeteHyper2.0 is offline   Reply With Quote
Old 07-03-2019, 12:18 AM   #3
BayStreet510
I actually went with the sub thump harness for the speakers and their harness to deactivate the noise cancelation along with a line out converter. It’s going to be a basic setup with one powered 12” sub.
The thing I can’t find a clear answer to is what do I use for the remote wire. I’m thinking a fuse tap into the “AMP” fuse but I’ve read that it has constant power.
Any idea where I can attach that remote amp turn on wire?
Old 07-03-2019, 06:57 AM   #4
tecboy
tecboy's Avatar
I used the wireless charge pad fuse in the trunk fuse box...
2016 Black 2SS A8 NPP Sunroof - Tinted Windows - Black Chrome Wheels - Custom Striping - ASC Sideskirts/Splitter - GM Lowering Kit - Complete Sound System - DD LED Sidemarkers
tecboy is offline   Reply With Quote
Old 07-03-2019, 07:55 AM   #5
StPeteHyper2.0
I have base model LT.. non Bose... I put a voltage meter and tried to find a fuse in the trunk with no luck. Mine doesnt have the charge pad option. Seems most of the ignition fuses are under hood. I tapped a couple of those for running gauges. I also tapped the 'passenger air bag' light for a dash cam. You can buy a meter for cheap and test your fuses, maybe you have something extra back there I'm un aware of
Old 07-03-2019, 08:21 AM   #6
JCurry2885
Drives: Black 2018 1SS Camaro M6
Use the cig lighter wire in the center console for remote turn on. Its pretty easy to pull the console out and access it.
JCurry2885 is offline   Reply With Quote
Old 07-03-2019, 08:30 AM   #7
ScatPack
ScatPack's Avatar
Drives: None at the moment
What is this, 1996?? Lol I had a system in my 91 Camaro RS. I had the custom box with a 12" Cerwin Vega. Man it thumped. Lol good times.
ScatPack is offline   Reply With Quote
amplifier, stereo, subwoofer
