![]() Drives: 2018 SS 1LE Join Date: Jul 2018
P10E4 trouble code
So guys, ran into my first issue with the car. Check engine came on upon start up, and doesnt go away unless I clear it. Tried checking google as well as ProDemand, it doesnt come up as anything for GM vehicles. Anyone ran into this code? If so what was the solution?
![]() Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
Some info on it in this thread:
https://www.camaro6.com/forums/showthread.php?t=555032 |
This is kind of an obscure DTC. A lot of stuff on the internet related to valvetronic systems, which we don't have.
As far as GM/Chevy, I did find this: https://static.nhtsa.gov/odi/tsbs/20...54263-9999.pdf This implies that a module may not be going to sleep properly, causing battery drain/voltage problems. |
![]() Drives: 2018 Chevy Camaro 1SS 1LE Join Date: Jun 2025
Good day. I just recently experienced this issue, code P10E4. Changed vehicle battery (OEM battery in vehicle, ~7 years old), cleared code, returned after 3 starts.
Got a key FOB message yesterday, low battery/change battery. Left key FOB @ home, went to backup FOB and the P10E4 code cleared itself. Will trend this and report back, FYI. |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
There's a lot of varying descriptions of this error code if you use google to search for it
But as it pertains to camaros. A P10E4 code on a 2020 Camaro SS likely relates to an issue with the throttle actuator, specifically a problem with the "A" control motor circuit that results in the throttle not being in the expected position. Potential causes include a faulty accelerator pedal position sensor, a bad throttle position sensor, an issue with the throttle control motor itself, or problems with the powertrain control module (PCM) or wiring. You'll need a diagnostic tool to read the code, and a professional technician can properly diagnose the specific cause and perform the necessary repairs. • P10E4 indicates a performance issue with the "A" control motor circuit of the throttle actuator, suggesting the throttle body isn't responding as expected. • Throttle actuator is the system that controls how much air enters the engine, dictating the car's speed and acceleration. Common causes • Faulty sensors: Problems with the accelerator pedal position sensor or the throttle position sensor can send incorrect signals. • Bad throttle control motor: The motor that physically opens and closes the throttle body could be malfunctioning. • Wiring issues: Corroded, broken, or loose wires in the throttle control circuit can disrupt communication. • Powertrain Control Module (PCM) problems: In some cases, the PCM itself may be faulty or require a software update. What to do 1. Use a diagnostic scan tool: A code reader is necessary to confirm the P10E4 code is present. 2. Inspect sensors and wiring: Look for any visible damage or loose connections in the throttle system and its sensors. 3. Seek professional diagnosis: A qualified technician can perform further tests to identify the exact component causing the issue and make the appropriate repairs.
Thank you Al Oppenheiser!
TL/DR, can be triggered by ECU power supply instability, due to harness mods.
After a long troubleshoot which included a borderline high starter relay coil resistance, the last page of this thread confirmed that a Gen5DIY harness mod affected the ECU enough to trigger the code. Gen5DIY updated the harness and fixed it: https://www.camaro6.com/forums/showt...=555032&page=4 |
