Old 06-26-2019, 03:27 PM   #1
BradfordCamaro
SABIO
BradfordCamaro's Avatar
Drives: 2016 CAMARO 1SS
My turn for enigine misfire P0300
Dealer replaced A=C compressor and the lines.
Now it is misfiring. Yippee. P0300 and P0305
Of course the dealer can do nothing.
In contact with my shop. (90 min drive)
Any thoughts?
No dealer bashing please. Doesn't help.
Old 06-26-2019, 04:27 PM   #2
Mosaic6SS
Drives: Camaro
I recently replaced my plugs due to a terrible idle (didn’t help much). However I noticed the spark plug on cylinder number one is really close to the AC compressor and lines there. You may want to check that plug and wire to make sure it wasn’t damaged or the plug wire is seated all the way. Other than that I found these TSBs.
I doubt this is your problem since the issue started after they did the work. But may give you ammunition to make them take a serious look at it instead of just resetting the light and sending you 90 minutes back.
Mosaic6SS is offline   Reply With Quote
Old 06-26-2019, 05:52 PM   #3
EMTNLSS
EMTNLSS's Avatar
Drives: 2016 Hyper Blue 2SS
Yea i'd check the wires and plugs first. I had a misfire a few days ago at idle and it was just a loose spark plug wire that pretty much fell off right as I touched it. Secured it back on and runs fine now.
I've also had the p0300 code before and I had to replace 2 injectors but this probably isn't your issue since it started after they worked on it.
2SS Hyper Blue Metallic | A8 | Jet Black Interior | NPP Exhaust
Current Mods: Catch Can | aFe Lowering Springs | GM 2nd Gen Splitter | Hotchkis Sway Bars | MRR FS02 Wheels | Flowmaster Exhaust | Dark Tail Lights | Diode Dynamics Sidemarkers | Roto Fab | Solar TB | PRAY Ported IM | BMR | PRAY Tune
Upcoming Mods:
EMTNLSS is offline   Reply With Quote
Old 06-26-2019, 07:37 PM   #4
BradfordCamaro
SABIO
TSB's are out...Cam and heads saw to that.
90 minute drive is to the performance shop that did my build.
Dealer is 5 minutes away.
Old 06-27-2019, 05:16 PM   #5
avalonandl
avalonandl's Avatar
Drives: 2019 ZL-1
Plug wire not fully inserted into one of the coils?
Old 05-03-2021, 03:00 PM   #6
joeyazzata29
j1ss
Drives: '21 2SS 1LE
What ended up being the cause of this?
joeyazzata29 is offline   Reply With Quote
Old 06-24-2021, 08:49 PM   #7
joeyazzata29
j1ss
Drives: '21 2SS 1LE
Did you ever find out what happened here?
