Old 06-26-2019, 12:34 PM   #1
overdriv
overdriv's Avatar
Drives: 1969 Chevelle SS 2019 2SS Camaro
Axle size ?
On my 2019 SS, I noticed the rear axles, half shafts, are different diameter size.
Why would they do this? I would think they would twist at different rate.
No thinking that would be desirable??
Any comments?
overdriv is offline   Reply With Quote
Old 06-26-2019, 01:34 PM   #2
awrj2000
Drives: 2016 2SS Camaro
Seen a video of this on a Cadillac.
Different weight between the two half shafts (helps) prevents wheel hop.
awrj2000 is offline   Reply With Quote
Old 07-12-2019, 07:54 AM   #3
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
Their torsional frequencies are intentionally mismatched to minimize resonance.
The larger diameter shaft is torsionally stiffer and has a higher frequency.
Old 07-19-2019, 09:34 AM   #4
overdriv
overdriv's Avatar
I suppose that makes sense. Did you guys just guess that, or you read it somewhere, or are you an engineer that knows about such things?
Old 09-04-2019, 10:11 PM   #5
cmitchell17
Drives: 17 2SS, 8L90, Cam, Heads, E85
I think this is an industry wide thing. In effect as Rock It Man said, its the same concept as the old tuning fork thing, you have one that makes one sound, then you hit another thats slightly different shape and length and they end up "eating" each other and canceling out. Same thing applies here, one driveshaft is sized perfectly right compared to the other one. It probably helps things like wheel hop a lot, gets smother delivery of torque for better traction, and helps prevent breaking things.
cmitchell17 is offline   Reply With Quote
