Old 06-22-2019, 01:09 PM   #1
Langhans2016
Drives: 2017 zl1 a10
Location: Missouri 2017 zl1. Cammed, magnuson 2650 973whp 889ftlbs
Zl1 magnuson 2650 build finally dynoed. 973whp 889ftlb
Langhans2016 is offline   Reply With Quote
Old 06-22-2019, 02:16 PM   #2
SienarSystems
SienarSystems's Avatar
Drives: ZL1 1LE
1st one in the wild? Congratulations and good luck with the build.
SienarSystems is offline   Reply With Quote
Old 06-22-2019, 05:46 PM   #3
Langhans2016
Zl1
Thank you! Should be starting on it early this week. A few parts still coming in
Old 06-22-2019, 05:51 PM   #4
Mcmillion
Drives: 2018 ZL1 1998 SS 1992 Typhoon
Awesome, can't wait to see the progress. Who's valve covers will you be using?
Mcmillion is offline   Reply With Quote
Old 06-23-2019, 12:04 AM   #5
Doc_Scott
Drives: GMC Terrain
Daaaaannnnggggg
Doc_Scott is offline   Reply With Quote
Old 06-23-2019, 06:07 AM   #6
laynlo15
Drives: 2022 Lt1 A10
Alright, now chad just needs to get his shit done to get you to the Camaro Fest with it and if mine gets here on time we will make the big debut. Hopefully some serious passes down the track.
Old 06-23-2019, 06:11 AM   #7
IneedAZ
IneedAZ's Avatar
Couple questions. Does this one also require hood trimming? By the looks of it, is it using two separate cooling bricks vs 1 big one?
Old 06-23-2019, 07:47 AM   #8
Langhans2016
Zl1
I bought the valve covers from speed engineering that they made for the 2650
Old 06-23-2019, 07:48 AM   #9
Langhans2016
Zl1
Can’t wait going to be a good time hopefully both of ours will be going!
Old 06-23-2019, 07:49 AM   #10
Langhans2016
Zl1
Shouldn’t need any hood trimming. And yes there are two separate bricks
Old 06-23-2019, 11:15 AM   #11
bmcc2584
Drives: orange SS LS3 6 speed
Sub’d looking into swapping myself. Are you installing yourself? Look forward to the end product. I’m a Missouri guy as well. Heat soak is real.
2018 ZL1 M6 bone MF stock
bmcc2584 is offline   Reply With Quote
Old 06-23-2019, 02:10 PM   #12
Langhans2016
Zl1
Yea I have been waiting to ditch the factory supercharger for awhile! I’m having chad Barton from CBI do the install. He has always done good work for me.
Old 06-23-2019, 03:34 PM   #13
regnouy37
regnouy37's Avatar
Drives: 2019 ZL1 A10
What kind of fuel upgrades are you looking to do, and what are your power goals?
regnouy37 is offline   Reply With Quote
Old 06-23-2019, 04:14 PM   #14
Langhans2016
Zl1
Starting out going to be trying for 900-950 whp. I have the bigger cam lobe, dsx low side, and lingenfelters bigger injectors and e85
