Old 06-21-2019, 05:46 AM   #1
Anim8er
Anim8er's Avatar
Drives: 2018 ZL1 Convertible
Tony Mamo or Soler?
Has anyone done the comparison between the two throttle bodies to see which is a better bang for the buck?
I'm looking to combine that with a Rotofab CAI....
If so, please share.
Anim8er is offline   Reply With Quote
Old 06-21-2019, 06:15 AM   #2
Joshinator99
Moderator
Joshinator99's Avatar
Drives: 2017 Camaro 2SS A8
The LT5 TB with adapter is more cost effective and flows more air than either one of those. Plus, it gives you room to grow, should you decide to put a smaller pulley on the blower.
Old 06-21-2019, 07:52 AM   #3
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Does the LT5 TB require a tune?
SHE'Z 18 is offline   Reply With Quote
Old 06-21-2019, 07:59 AM   #4
Move'n Up
Move'n Up's Avatar
Drives: 17 Z06/Z07, 17 2SS Fifty, Ram 2500
Yes
Build Date 8/1/2016 1,109 out of 5,982| Club F1FTY
Move'n Up is offline   Reply With Quote
Old 06-21-2019, 08:05 AM   #5
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Originally Posted by Move'n Up View Post
Yes
Thanks Move'n Up...
Old 06-21-2019, 08:09 AM   #6
cirpower
Drives: Camaro ZL1
Can you even fit the LT5 TB to the OEM supercharger? I thought you needed to at least port the snout?
cirpower is offline   Reply With Quote
Old 06-21-2019, 08:11 AM   #7
Move'n Up
Move'n Up's Avatar
You have to use an adapter ring. There are a few companies making them now. Also need the ring because the bolt pattern is different on the LT5 TB. Porting the snout is highly recommended but not required.
Old 06-21-2019, 08:46 AM   #8
Hilltopper
Drives: 2018 Camaro ZL1, 2017 Z06/Z07
I have removed the Mamo TB and replaced it with a Soler on my Z06. The Mamo is an improvement over OE, the Soler is a significant improvement over the Mamo, in my experience. When I purchased my ZL1, the first thing I did do the car was install a Soler TB and Roto Fab CAI. Skip the Mamo and go straight for the Soler. Follow the relearn procedure and never look back.
___________________________________________
2018 ZL1, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, ATI Underdrive Pulley 673/688, 2017 Z06/Z07, Kong Ported LT4 SC, Kooks 2" Headers and X-Pipe, NW103mm TB, IW 18% Underdrive Pulley 640/664, 2019 Mustang GT Perf Pkg. 1
Hilltopper is offline   Reply With Quote
Old 06-21-2019, 09:16 AM   #9
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
Did you have an codes during the "re-learning" phase after installing the Soler? I have a few pending questions to Mike at Soler that I'm looking forward to getting the answers to. However, it sounds like a solid product. Especially for a bolt on.
Thanks brother..
Old 06-21-2019, 10:28 AM   #10
Mike@SolerPerformanceLLC
Mike@SolerPerformanceLLC's Avatar
Drives: 2015 Corvette Stingray
Anim8er, we are proud we at least made to the finals, thanks for that.
All we'll ask is that you look carefully at the number of features, surface finish, performance plots, geometry scans.
Many comparisons done by Corvette 7 owners (LT1/LT4 Engines) and posted at corvetteforums.com.
Tiffany,
Soler Performance LLC,
support@solerengineering.com
www.solerengineering.com
(251) 468-9786
Mike@SolerPerformanceLLC is offline   Reply With Quote
Old 06-21-2019, 10:31 AM   #11
Shoot, customer service is my job here at the forum. Thx.
Tiffany,
(251) 468-9786
Old 06-21-2019, 10:34 AM   #12
SHE'Z 18
SHE'Z 18's Avatar
Drives: 18 ZL1 - M6
You bet! I posted some questions on the other Camaro6 ZL1 thread that's active (ZL1 Owners, This Super Easy and Very Effective Mod Is For You Too"). When you have a second, can you please advise? Thanks Mike...
Old 06-21-2019, 10:36 AM   #13
Brettmess24
Drives: 17 C7 GS WGG
Tony Mamo or Soler?
Katech PTB and RotoFab w/standard filter.
Brettmess24 is offline   Reply With Quote
Old 06-21-2019, 10:46 AM   #14
ZL1 1LE
@zle_blackwing
ZL1 1LE's Avatar
Drives: 2018 ZL1 1LE
There’s an option for both. Soler will perform their modifications to a TB that’s already been ported by Mamo.
