Rear toe in/out problem
I have a stock 2017 1SS and the passenger rear tire keeps wearing on the inside faster than the drivers side. Is this a known problem? Can I have the toe out or in adjusted so it will wear in the middle of the tread? I have Firestone lifetime alignment and they do not like straying from the factory specification on alignments.
Is this because of the way the Independent Rear Suspension is set up or do I have bigger problems somewhere else? Any input would be appreciated. |
"M1SS1LE"
Drives: 2017 SS 1LE Join Date: Dec 2015
Rear toe and camber bolts are technically 1 time use. If they have been adjusted multiple times they may not be holding the alignment from shifting anymore. I would buy a new set of bolts and have them dial the rear back in. You want the toe as close to 0 as possible to avoid accelerated wear.
BTW the front is completely reusable hardware, so it can be adjusted as often as you like.
#3 | |
#4 | |
![]() ![]() ![]() Drives: 2017 1SS 1LE Join Date: Jun 2016
They should also give you a print-out of the alignment measurements before and after they adjust it. You might also be able to pull out the camaro track prep guide and convince them to do the track alignment (close to 0 toe) if you get a tech/manager that's willing to cooperate. Track prep guide can be found here.
2017 SS 1LE.
#5 | |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 2SS Convertible Join Date: May 2012
