![]() Drives: Camaro Join Date: May 2017
Need more headroom
I recently purchased a 2019 2SS with sunroof and am having issues with headroom. I previously had a 2016 LT/RS without the sunroof and had no issue. Not sure how I didn’t notice during the test drive, I assume because I had the sunroof open and the wind was blowing, but my hair brushes the headliner in the afternoon/evening. I have to actually adjust the seat in the morning because it’s much worse (slightly taller in the morning). I make it work by putting the seat all the way back, but it’s too laid back for my taste.
The dealer isn’t helping me out when I requested to swap for a non-sunroof model, so I’m trying to figure out what my options are. Is there anyway to fab the seat rails, or different seat rails perhaps? If I purchased the stock Recaro seats that come in the 1LE, would that give me any more room? Only other thing I can think of is getting racing seats, but would prefer to avoid that because I want to retain the factory airbags and heated/cooled seats. Any suggestions would be much appreciated. |
Who Needs to KNOW?
Did you sit in the car before you bought it ?
Racing seats and raials can reduce overall height, but see ya later airbags, etc.
#3 | |
Yeah that’s my concern, the airbags. That’s why I’m mostly curious about how the Recaro seats in the 1LE would be. |
#4 | |
![]() Drives: Chevrolet Camaro Join Date: Apr 2019
Maybe you can remove the seat and see if anything can be done w/the bracket to lower it. |
![]() ![]() ![]() ![]() ![]() Drives: 08 Tiburon GS, 2018 Camaro 2.0T Join Date: Sep 2017
In the morning sometimes you tend to sit a little more higher in the seat while in the afternoon you lay a little more down since you are getting tired. I have the same situation in my Tiburon where even if the seat belt adjustment on the shoulder is at the lowest point, it will run against my neck (annoying...). But it is worse in the morning.
Maybe try to see with the dealer if they can convert your purchase to a lease and if you ever find someone who's willing to buy back your lease you could then buy another without the roof? It's worth trying...
2018 Camaro LS | 6 spd | 2.0L turbo | Nightfall Grey | RS package | Technology Package.
--------------------- Order WDGHKX 1100 - 5/08/2018 | 3800 - 6/18/2018 2000 - 5/09/2018 | 4200 - 6/21/2018 3000 - 5/28/2018 | 5000 - 6/27/2018 6000 - 6/29/2018 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 ZL-1 Join Date: Feb 2009
The seat mounting brackets SHOULD NOT be messed with. They are structural and integral to the occupant safety. You can have some foam shaved off the seat cushion to gain that 1/2 inch- any good auto upholstery shop can do that.
2012 Yukon XL Denali w/ 6.2 AWD |
#7 |
Yep! You’re actually almost 1/2” taller in the morning. Your spine compresses during the day, that’s why later in the day, it’s not a huge issue. My hair might brush the headliner depending on how I’m sitting.
#8 | |
Do you have any idea if the Recaro seats would help out? |
#9 |
![]() Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
Shave your head. Problem solved.
#10 |
![]() Drives: 2019 Camaro 2SS A10 Join Date: Feb 2019
Haha... I thought he was rocking a perm or something, and it flattened out throughout the day. I'd never heard of the spine compressing throughout the day, then again mine is mostly made of Titanium, so probably not compressing too much.
The sunroof must really cut into headroom? My 16 year old son is a little over 6'6" and when he drives my 19 2SS, it's snug, but his head doesn't rub the liner (non-sunroof). Are you getting full adjustment with the seat controls? Able to lower the seat fully?
2019 2SS: A10, Satin Steel Gray Metallic, MRC, Nav.
#11 | |
I’ve spent quite a bit of time adjusting settings to find a balance. It’s actually not a problem if I recline the seat back all the way, but I just feel so disconnected from the car being in that position. I’ve moved the seat closer to the wheel and moved the wheel down a little, and that helps. It’s just annoying because I want to sit up more. Think I’m going to stop by the dealership and sit in the one I test drove to find out if I’m crazy or not. Wouldn’t it be wild if my seat had an issue and wasn’t going down all the way. |
#12 |
Who Needs to KNOW?
Does your car have Easy-Exit feature ? Where it slides seat to "exit" position ?
#13 |
#14 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro ZL1 Coupe Join Date: May 2016
I’m thinking that Camaro QC might have a good idea for you and I really don’t think switching out the seats to Recaros will help your situation. The Recaros are expensive too!
| Tags |
| headroom, recaro, seats |
